1952 Ford F-6 question - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-19-2008, 04:47 PM
greasemonkey383's Avatar
Senior Member
Just wondering if anyone makes a suspension lift for a 1952 F-6. I got it for free from my uncle and I want to lift it and get some bigger wheels and tires. Im also thinking of a diesel swap and automatic tranny. I also want to change out the old axles and put in a D-70 rear and soild beam front axle.
Old 06-19-2008, 06:42 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Highly unlikely any one makes a lift kit for that..you are on your own there...52 F-6 to me was a heavy duty Ford truck and has the beam axle in front...Doing a diesel in one of those is doable..
Put up a Picture so we know better just what this truck is..
Sam
Old 06-19-2008, 07:15 PM
Brian_B's Avatar
Lost in the 50s!
Last journal entry: time to start body work
AFAIK...the F-6 was the big truck at the time. Unless the COEs were larger?
No lifts available. If you are swapping suspension, why worry about a factory type lift? You will have to fab parts to put the new suspension in and nothing factory made would fit then anyway.
The cab on the F-6 should be the same as the F-1. The fenders have a much larger opening. I am not sure about the hood, but I think it is the same as well.
There are not a lot of people into the big trucks. They are rather hard to find parts for (other than cab parts).
They are getting a little more popular now that the smaller ones are getting hard to find. Still parts are an issue.
Old 06-20-2008, 12:05 PM
whatwouldscoobydo's Avatar
F-5,F-6 is considered a 1 1/2 ton.The front fenders will bolt on, as the cabs are all the same from 1/2 ton up,but the wheel well opening is larger.
Ford Steel Wheel Tech wheelkid General Rodding Tech 9 01-07-2007 06:31 PM
ford truck question william r plise Body - Exterior 3 05-11-2006 05:38 PM
Wanna Talk Cars "Fords" 66Falcon Hotrodders' Lounge 17 10-01-2005 05:29 AM
question for all you ford suspension guys Blag Suspension - Brakes - Steering 7 03-29-2005 11:59 PM
34 Ford fuel tank question 302 Z28 General Rodding Tech 1 02-01-2004 04:55 PM
