1952 Ford Mainline floor pans - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Introduce Yourself
Old 02-19-2006, 07:58 PM
i am new to this form ! i hope to make some friend and find & trade all the information that can be giving! i am buying a 53 ford mainline . she will be my first rat Rod ! I am trying to find some floor pans and body parts to patch her up . she only has a 6 cyl but she does run ! i will put a small-block 351w in later . any place to start to fix the floor pans . i also want to know what is the best welding to use for the floor pans and body work ? MIG--TIG or what is the EASIEST to work with . i have only used a torch about 20+ years ago !!
Thanks,Jim
Old 02-19-2006, 08:06 PM
poncho62's Avatar
Wiki Edits: 5
welcome Jim.......Post your questions in the body forum...you will get your answers there.
Ontario Rodders
Old 02-19-2006, 08:08 PM
Thanks alot ! i will go there and try that .
Thanks,Jim
Old 02-19-2006, 08:37 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Welcome to Hotrodders , Poncho is right place your questions in the proper forums. I think a MIG is best for that floorpanwork.
Old 02-22-2006, 10:39 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
WELCOME TO HOTRODDERS.COM
The Most Innovative Site on the Net
Thanks for Joining
R
"SlowRide66"
"Illegitimis non carborundum"
Crankshaft Coalition Master List of Hotrodding Forums
Ford Rear Discs, revisited. DONE! Psquare75 Suspension - Brakes - Steering 39 07-18-2006 06:10 PM
M.S. requested joke thread hotrodit Off-Topic 186 12-20-2005 12:26 PM
SB Ford Starter Fifty5F100 Engine 1 12-21-2003 07:56 PM
Enhance a Ford 8" or ?? Strick Transmission - Rearend 13 07-18-2002 06:16 AM
40 Ford Dash in a 37 Ford?? Carnut39 Interior 1 12-05-2001 05:51 PM
