1952 Pontiac - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-07-2004, 08:27 AM
1952 Pontiac
I have a 1952 Pontiac with an Automatic Transmission. I need to replace the Ring Gear on the flywheel. The Torque Converter is bolted to the flywheel with about 40 bolts. I think that there is a gasket between the converter and the flywheel. I need to know if there is a gasket and also where I can get one. I also need to know where I can find the ring gear.
Thanks Bob
Old 11-07-2004, 09:31 AM
Crosley's Avatar
Wiki Edits: 1659
Cool
there will be a gasket or a rubber O ring on the converter.
A supplier of old tranny parts is Fatsco in New york ( If I remember)
Fatsco.com may be the web site.
Old 11-12-2004, 02:02 PM
Thanks for the site. I sent an Email to them about my parts.
Thanks again Bob
Old 11-12-2004, 02:17 PM
willys36@aol.com's Avatar
Wiki Edits: 21
That's a dual range Hydramatic, the same one that all the gasser drag racers converted to Hydros in the 60s. The can is covering a fluid coupling, not a torque converter. They are quite different in operation. There is a paper gasket that must be replaced every time you open the can.
Call Transmatic in LA, 818-246-7788 for all the parts you need. Another source is John Kilgore, 412 S San Fernando Blvd., Burbank, CA 91502, 818-843-7180.
Old 11-12-2004, 05:39 PM
Crosley's Avatar
Wiki Edits: 1659
Cool
Good ol John Kilgore. A sharp fellow.
I bought my first stall speed converter from John in the early 1970's. It blew up internally as I pulled into the drive of my house.
I bought my second converter from a local Phoenix company... Hughes Machine , now known as Hughes Performance
