1953 Buick Special-front end rear end?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-28-2009, 03:12 PM
Greetings:
I have a1953 Buick Special 2Dr 45R series car.
My plan would be to upgrade the front end by installing disc brakes and a power steering unit in the front and then swapping out the rear with a later
one that has drum brakes.
Would installing a Mustang II stub and front end be the way to go? If so, whose kit would you recommend? And, what donor car would you recommend for the rear?
Thanking you in advance, John Bach
Old 11-28-2009, 03:59 PM
I installed a fatman front clip and 96 impala rear under a 50 buick went together without any issue
Old 11-29-2009, 06:36 PM
Bundy 72:
Thank you, I appreciate the reply.
mbjeep
Old 12-03-2009, 03:25 PM
oldguy829's Avatar
Last wiki edit: Swapping to rack and pinion steering
Last journal entry: 53 coupe
Wiki Edits: 88
53 buick
I had a 53 buick special 2 door (about 40 years ago) and I remember a big heavy car. I wouldn't put an MII under it on a bet. Look at this wiki
http://www.crankshaftcoalition.com/w...ension_upgrade
might give you another point of view.
Old 12-03-2009, 07:25 PM
Old Guy 829
Thanks for the reply.
mbjeep
Old 12-05-2009, 07:30 PM
I looked at the article from crankshaft col, whoever built the upper control arm bracket shouldn't be allowed to look at a welder let alone use one.I thought the same thing about the weight being an issue,we checked the weight and it was 3600lbs not as much as I thought.I talked to fatman and they said there are some COE's running their front suspension without any problems.Yhe MII control arms use bigger balljoints the the fullsize ford trucks and that would be the weak link.personally after using a couple of their front clips I would use it on anything.[IMG][/IMG]
Old 12-06-2009, 12:41 PM
Bundy 72:
Thanks again for the additional information.
Every little bit helps.
mbjeep.
Old 12-06-2009, 02:15 PM
Oh buy the way the 96 impala rear I used was narrowed 3" over all.It depends on the wheel and tire you are using,the 50 buick I did had 20x10 torq thrusts.[IMG][/IMG]
Old 12-06-2009, 06:32 PM
Bundy 72:
Beautiful car.
mbjeep
5 on 5" rear end swap in my '62 GMC - 10 bolt vs 9" vs Dana 44 Chuck78 Transmission - Rearend 8 07-22-2008 10:01 PM
adjusting door fender gaps on 60s ford? 62galaxiguy Body - Exterior 1 06-13-2008 07:43 AM
Front Clip For A 55 Buick Special ELMO Suspension - Brakes - Steering 16 01-15-2004 02:28 PM
Rear end Buffed Engine 3 10-31-2002 05:11 AM
Tables of rear end and front end dimensions willys36@aol.com Transmission - Rearend 1 08-21-2002 05:33 PM
