1953 Chevy 3100 Drive line angle questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-17-2014, 04:22 PM
I have a 1953 Chevy 3100 that I grafted a 1977 Nova sub frame onto. In the back I have installed a Ford 8.8" posi rearend with 4.10 gears and disc brakes out of a mid 90's Ford Explorer.
I got it positioned and made some supports for the rear shackle mounts.
Name:	53 Project shackles 005.jpg
ID:	113458   Click image for larger version
Name:	53 Project shackles 006.jpg
Old 01-17-2014, 04:25 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
moving to suspension forums
Old 01-17-2014, 04:26 PM
The truck will have a 350 engine matted to a 700r4 transmission. I will have to get a drive shaft made, but right now I need to figure out my driveline angles.
As the rearend sits now in the chassis with NO body weight, I have a 14 degree pinion angle. I know that they make shims to correct this. What suggestions do you guys have?
Would I be better off to order a 10-12 degree shim kit or cut the spring pads off and reclock them on the axle tubes?
Old 01-17-2014, 04:28 PM
Sorry! I clicked submit before I completed my thought process.
I was not sure if this fell under "suspension" or "driveline."
Old 01-17-2014, 06:22 PM
poncho62's Avatar
Wiki Edits: 5
I would redo the spring perches.......The angle of the drive shaft coming off the transmission should be the same as the drive shaft going into the rear end
Old 01-17-2014, 08:08 PM
bbeins's Avatar
Harbormaster
Last journal entry: Steering Linkage
I have a similar project, 350sb, 700r4. I went with a 4 bar rear suspension with coil overs off the axel tubes. and my angles are both 3 degrees. definately need them the same. That seems pretty severe.
Old 01-18-2014, 10:09 AM
How much do you think my pinion angle will change once the body and accompanying weight is sitting on the frame?
Old 01-18-2014, 10:13 AM
Everything that I am reading and hearing is 2-4 degrees is ideal. I guess I need to get the engine/transmission situated before I worry too much about pinion angle.
Old 01-18-2014, 12:52 PM
bbeins's Avatar
Harbormaster
I estimated weight of fuel,passengers, and yet to be installed body parts and piled weight to frame to get close. I probably got to 2 to 4 degrees off this forum, and went with 3.
Old 01-18-2014, 01:50 PM
bbeins's Avatar
Harbormaster
Old 01-18-2014, 02:34 PM
While we are discussing angles, here is another question.
The Ford 8.8" differential is not centered and the yoke is 2.5" off center. I know this is different than pinion angle, but it is this something that needs to be considered?
Old 01-18-2014, 03:02 PM
RWENUTS's Avatar
Here's a link that should answer most of your questions.
http://www2.dana.com/pdf/J3311-1-DSSP.pdf
Old 01-21-2014, 08:32 AM
Interesting read - thanks!
I am concerned about the "compound" angle on the driveshaft, since the 8.8" is not centered. The drive line will be angled left and up.
Does anyone have a setup like this? Do/did you have any issues with vibration?
Did Ford offset engine/transmission location to the right since the differential is offset 2.5" to the right?
Old 01-21-2014, 09:03 AM
life is a temporary assignment
As far as I know,,Some fords came that way..
Chevy 3100 1953 truck redo joegulley Introduce Yourself 2 06-06-2013 03:31 PM
1953 Chevy 3100 hood scadycole Hotrodding Basics 4 05-23-2011 11:50 AM
1953 chevy 3100 1/2 ton truck project joegulley Introduce Yourself 1 07-21-2010 12:39 PM
Upgrade Ford 4 flat-head drive line with V8 drive line up to 1937 (mechanical brake) roundhousedog Transmission - Rearend 0 07-23-2009 04:29 PM
Long Block in a 1953 chevy 3100 truck chevy53 Engine 3 07-02-2007 09:47 PM
