1953 chevy oil plug need to remove it - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-15-2010, 11:14 PM
buggmann's Avatar
build it like you like them
Last journal entry: buggmann stilling looking
Wiki Edits: 2
i have a 1953 chevy it has a 235 straight six
i need to remove the plug were the oil return
line go's for the oil filter i can't get it out any idea's
thanks for the help
thanks buggmann
Old 09-16-2010, 01:00 AM
techinspector1's Avatar
Wiki Edits: 326
Heat the area around the plug to a dull red, then smush a candle up against the plug and let the wax weep into the threads. That has worked a time or two.
Old 09-16-2010, 03:28 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
X2 on the heat, Richard i have never used a candle but i will remember this.
I can see how it would work when the wax gets into the threads makes perfect sense. . Thank you i just love to learn.
Cole
Old 09-16-2010, 03:37 PM
Old wrecking yard trick is to smack the head of the bolt with a hammer. Give it a few "good" whacks, should break loose with no problem. Heat is another good idea, but with dealing with oil you might end up with the oil catching on fire.
Old 09-16-2010, 04:26 PM
buggmann's Avatar
Wiki Edits: 2
buggmann
ok well it not a bolt it more of a square head plug
it about the size of a 7mm -8mm bolt but the thing
is i dont have a good way of getting it out so that
is were the prob is so i know the heat would work but
then how do you get a grip to get it out
thanks for the help and ideas
Old 09-16-2010, 08:23 PM
tnovot's Avatar
You could try an 8 point socket.
Old 09-16-2010, 09:31 PM
evolvo's Avatar
Vise grips
Old 09-16-2010, 09:41 PM
life is a temporary assignment
Put a bigger nut over it, Weld the center of the nut to the plug... Fill in the hole in the nut.. It will give you something to put a wrench on, Plus the heat will also help.. I got many out this way.. Hope this helps..
Old 09-16-2010, 09:57 PM
Dirty Biker's Avatar
Bold As Love
Could you just not just drill it out and tap bigger threads?
Old 09-16-2010, 10:54 PM
buggmann's Avatar
Wiki Edits: 2
Buggmann
Well see thats what i was thinking but just was not sure how big i needed to
go see i was going to drill it out to fit a 5\16 line and go from their but was not sure see i have seen some people use metal line and not the rubber see i have both so what way to go
Old 09-17-2010, 12:10 AM
Bold As Love
Try drilling a small hole in the plug first and using an easy out on it. You may have to grind it flat and use a center punch to get the bit to stay center. Then if it comes out you can just use another regular plug. If it wont come out with the easy-out then I wouldn't drill it any bigger than you need to to get the very next size tap in there. I think rubber fuel line would be fine for a guy like me but metal brake line is obviously better and I think it looks nicer too.
Old 09-17-2010, 06:54 PM
Panelman55's Avatar
Loving God living in the South
Apply heat first, candle if you like or a good penetrant (brake free, Kroil, Zep 45 etc) reheat again and tighten the plug. Yes tighten. Then reheat and remove the plug. This is the method I use most often with good results.
Old 09-17-2010, 09:57 PM
buggmann's Avatar
Wiki Edits: 2
buggmann
well i have tryed a lot of things but i have yet to get it out
i just wish i had a good source of heat so i could get this done
now im driving the car every day see the car was not built with
a oil filter so i got a factory set up and need the plug gone so i
can hook this up i will try some more things and well let yall know
Daily funny--- Revisited schnitz Off-Topic 4175 03-25-2017 12:30 PM
Oil on spark plug threads 350pano Engine 12 02-25-2016 06:38 AM
Oil change nuisances Slipangle Hotrodders' Lounge 13 10-09-2009 03:32 AM
changing plugs?on a V10 ford?how!? bonzipenguins Engine 23 06-03-2009 06:29 PM
Oil Priming - Chevy V8 - No Oil to Lifter Bores - Help leejoy Engine 4 03-09-2008 10:55 PM
