1953 chevy truck with a 502 - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-07-2013, 07:26 PM
I am in the early stages of my project and trying to form an attack plan.
The truck has a great factory frame, 10 bolt rear and no front suspension whatsoever.
I want to do a mustang II front end and have a line on a 502 roller motor for cheap.
Will the 502 fit in this truck? (Obviously needs a different firewall.) And if so, what spring rate would I need in the front?
Pardon the mess..too many projects goin at once
Old 04-12-2013, 07:34 PM
techinspector1's Avatar
Wiki Edits: 326
Yes.
I doubt the 502 is any longer front to rear than the six that came out of the truck, so why would you need a different firewall?
Call these guys and tell them what you are doing. They are the experts in matching springs to hot rod engine swaps.
Eaton Detroit Spring Home
Old 04-23-2013, 01:38 PM
496CHEVY3100's Avatar
Built Not Bought
Last journal entry: 53 ad3100
Originally Posted by techinspector1 View Post
Yes.
you will Not need a new firewall for clearance ,I replaced mine to smooth it up, but it fit before I replaced it.
ID:	73496   Click image for larger version
ID:	73497   Click image for larger version
ID:	73499   Click image for larger version
Old 04-23-2013, 01:51 PM
life is a temporary assignment
A small block fit's fine in them so a big block is no different,, The only difference between the two is from the mount forward,, You can put a 502 and anything if you have the right tools..
Looking forward to seeing this come together..
Old 04-23-2013, 02:43 PM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
If you plan to put that power down, expect to replace that 10 bolt though-I have a 540, 9" w/31 spline axles/4-pin trac-loc, and I am replacing that with a Strange Al, Detroit true trac 9" w/35 spline axles to handle the torque-
Old 04-23-2013, 08:27 PM
Built Not Bought
Summit ,Jegs ,and several companys offer a bolt in engine & trans mount to put a small or big block in your truck .they are around a $100.00 they bolt from side to side frame rails which helps to strengthen the frame.if you use rack & pinion you will need a stereing shaft with a 3rd u joint .they installed several at the shop this year ,its fairly straight forward install ,if you use a big block try to find a short water pump setup for a 66 -72 corvette,or 69-72 p/u you will not have to trim front radiator surround as I did on mine.also if you use coil overs on front 350 lb rate seem to work the best for us
Old 04-25-2013, 07:53 PM
Built Not Bought
Are you running leaf on rear or 4 link and coil over,i am running 4 leaf rear at this time,but are looking to change to some thing else I have a 84 corvette complete rear but it is much to weak,
Old 04-26-2013, 07:55 AM
35WINDOW's Avatar
I am running a Pete & Jakes 4-Bar-we'll see if it can hold up to this-
Old 05-05-2013, 03:54 AM
Built Not Bought
With inner fenders installed.
Name:	Inner fenders 002.jpg
ID:	73764   Click image for larger version
Name:	Inner fenders 001.jpg
Chevy 3100 1953 truck redo joegulley Introduce Yourself 2 06-06-2013 04:31 PM
1953 Chevy Panel Truck Connie Schrader Interior 1 03-03-2013 02:47 PM
1953 Chevy Truck Vin Help Homeseller Hotrodding Basics 14 08-12-2012 10:24 AM
1953 chevy truck hood jstgtnstarted Body - Exterior 7 04-23-2008 05:55 PM
1953 chevy truck need help mlaseter Body - Exterior 2 04-23-2008 05:53 PM
