Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1953 ford f100 drivetrain swap
Old 06-28-2012, 10:12 PM
Canzus's Avatar
Canzus Canzus is offline
a red wool sock on his dinger
Originally Posted by dusterbd View Post
problem is, theres no motor mounts, and no body. so how do i know where to locate the motor? does anyone have any dimensions for me?
I don't have a dimension, but if you mount the notch in the oil sump over the front axle,
you'll be close to the correct measurement for fore/aft position, but as a warning, DO NOT
BUTCHER THE CROSSMEMBER AT THE ORGINAL BELLHOUSING
MOUNT...
Just raise the engine/tranny, level it using the carb mounting on the intake, build a trans mount
and you're done...
also, since i am NOT a ford guy.....
what factory distributor should i use? the motor is out of a 92 mustang, withn an edelbrock intake and a carter carb.
1985 Mustang GT with a 5L HO (4bbl carb) Has the steel gear you'll need for the roller cam,
and a vac advance as well. O'reilly Part # 30-2831 Also, you'll need a module to run the ignition...
also, well be using a c6 automatic behind it (again, tried to talk him into an AOD, but he wants a 3 speed....) what do i do for kickdown linkage?
im mostly a mopar/subaru guy, so please point me in the right direction.
thanks
Michael
Does the carb have the Ford kickdown lever? I'd probably opt for the Lokar(sp?) cable...
__________________________
Steve & The Rockette...
Too many toys to list...
PS: Sorry you had to wait this long for an answer to your really simple questions, but such things
happen when the smart guys get chased off by certain moderators...
Last edited by Canzus; 06-28-2012 at 10:18 PM. Reason: Clarification on the length of time for an intelligent answer
