Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1954 Bel Air Restoration
Old 10-10-2012, 10:26 PM
matt167 matt167 is offline
Wiki Edits: 31
Yes. with the OD, it probably could do 70 MPH on the highway. Stock form it probably won't hold the speed very well on anything other than flat ground. dual carb Intake and headders will strengthen it up quite a bit tho.
