Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1954 Bel Air Restoration
Old 10-11-2012, 07:00 AM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
Originally Posted by gdstock View Post
Thanks for the info!
Could the 235 be upgraded to handle the 700R4? i understand that the early corvettes had the 235 in them. I would really like it to handle 70 mph pretty easily if it can be done (without costing a fortune). I'll look for a Camaro rear end!
A 235 inline 6 engine will require an adapter setup to install the 700r4 trans onto the 235 engine. LAst time I checked that adapter setup was in the area of 550.00 to 600 dollars
