1954 Chevrolet Engine Issue - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-22-2010, 10:09 PM
I'm working on a 1954 Chevrolet with the 235 inline 6 cyl. There is fire to the engine, however, it will not run. It is backfiring out the carburetor and that is it. Could it be a timing issue, or what?
Old 07-23-2010, 06:20 AM
BOBCRMAN@aol.com's Avatar
Timing or ignition wire fowl up. Find TDC no.1. Then rewire cap proper firing order.. Most 6's 153 624..
Old 07-23-2010, 07:42 AM
Wiki Edits: 31
check the cap for carbon tracing carefully.. shut my '51 235 off 1 day and couldn't restart. pop and crack every once in a while, and I replaced points, wires, but still had no go.. checked distributor cap and it had bad carbon tracing, so I threw an older 1 on it and it ran
Old 07-23-2010, 11:03 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If it is popping from the carb, the timing could be too advanced. Have you turned the distributor from where it was originally? If you can, put it back where it was, or turn it CW to retard it from where it now is and retry.
It could be the points or condenser are bad, the points dwell could be off.
Old 07-23-2010, 01:58 PM
yes all ways check your points i had that happen one time over looked them replaced all kinds of stuff that didn't need to be replaced... the car ran great shut it off and when i went to start it same thing cracking and popping sounded like it wanted to run even started once ran like crap though..
acceleration flat spot in carb. corvettetonybone Engine 17 04-13-2013 09:31 PM
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 11:00 PM
1968-1969 olds 455 engine is this good and how can i id 1968olds455HO Engine 5 09-02-2009 12:53 PM
1954 Chevy inline 6 (235cid) engine specifics Riot Racing Engine 5 05-09-2009 12:39 AM
Whatever happend to these guys? hot_rod_kid Hotrodders' Lounge 20 12-17-2002 10:20 AM
