1954 chevy 210 - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 04-30-2012, 12:29 PM
Yep, 18 gauge mild steel is all you need. That will be thick enough for some strength and thin enough to be able to bend it. But there is some serious forming needed for that floor so be ready for some work.
And without a shadow of a doubt you need to do those rockers first if you are making the floor. You need all that stuff solid and straight, then you make the floor fit the structure.
  #17 (permalink)
Old 04-30-2012, 12:43 PM
Originally Posted by 54Rat210
I do have some cinder blocks I can use under the pillars just in case.
Cinder blocks are not made to hold much weight. You want to put them like this photo and then put a 2x6 or 2x8 piece of wood over the top so the weight gets distributed evenly. Setting a rocker pinch weld on one is sure to split it wide open.
  #18 (permalink)
Old 05-02-2012, 04:44 PM
Thanks for all your advise Brian.
  #19 (permalink)
Old 05-02-2012, 10:32 PM
No problem, but I still would like to see you toss those cinder blocks out in the garden to make a garden boarder or something and use wood blocks for your car.
  #20 (permalink)
Old 05-02-2012, 11:13 PM
Didn't need the cinder blocks. I figured the rockers were so destroyed that if any damage was done its already done. There was almost no rocker panel. Completely rusted and packed with old *** bondo. I took a look everything is still lining up. Tacked up the inner rocker and part of the back floor pan. No problems.
  #21 (permalink)
Old 05-02-2012, 11:17 PM
Trail fit the doors, don't cheap out or you could be very sorry.
  #22 (permalink)
Old 05-06-2012, 07:28 AM
deadbodyman's Avatar
Wiki Edits: 11
fitting the doors first is most important..the body might be sagging so if the gaps at the bottom get wider and cant be adjusted out you'll have to lift the body up or pull the gaps together with a come along..once you have the gaps right weld youe supports on the inside of the car so you can leave the doors on and open and close them while your doing the rockers checking the gaps for any changes throughout the job...
One of the things that'll through you off is those rotted out rubber body mounts theres a couple ways to elimanate this from becoming an issue..you can replace them first or replace them all with some with some dummies made with plywood and a hole saw they'll hold the car up evenly all the way around as long as the frame outriggers are intact....Heres a few old pics of how I did mine and what was involved...
BTW I started out using 1/2 x 1/2 square tube but found 3/4" electrical conduit worked well also and plenty strong enough since the forces excerted on it will be trying to streach it or push it ( like a drinking straw is very easy to bend but try to pull it apart or crush it by pushing the ends and its much much stronger ...The nice thing about using conduit is you can flatten the ends and use 1/2 drill screws to hold it all together (no welding)
ID:	65185   Click image for larger version
ID:	65186   Click image for larger version
ID:	65187   Click image for larger version
ID:	65188   Click image for larger version
  #23 (permalink)
Old 05-06-2012, 07:34 AM
Wiki Edits: 11
Heres a few more
ID:	65190   Click image for larger version
ID:	65191   Click image for larger version
ID:	65192   Click image for larger version
Name:	100_5245 (Small).jpg
ID:	65193   Click image for larger version
Name:	100_5247 (Small).jpg
  #24 (permalink)
Old 05-06-2012, 07:54 AM
Wiki Edits: 11
and a few more still,I got a ton of em
ID:	65195   Click image for larger version
Name:	100_5705 (Small).jpg
ID:	65196   Click image for larger version
ID:	65197   Click image for larger version
ID:	65198   Click image for larger version
  #25 (permalink)
Old 06-02-2012, 08:29 PM
I'm pretty sure I'm using 3/4th conduit. I spoke with a buddy of mine who restores classic cars and he basically told me exactly when u said. So far I got the inner rocker in and floor one rear floor board completed. its been going pretty smoothly. Nice photos. My cars rockers looked identical to the ones in your photos...gone! Lol sorry for the delay in response I been rather busy the past could weeks.
  #26 (permalink)
Old 06-03-2012, 04:48 AM
Wiki Edits: 11
Sounds like your making a lot of progress, post some pics.it's an interesting job.
  #27 (permalink)
Old 06-03-2012, 09:29 PM
I would love to see some pics too. It has been great to watch Mikes car coming together. Look forward to seeing yours progressing also.
  #28 (permalink)
Old 06-10-2012, 07:20 AM
Wiki Edits: 11
Me too,The only thing I like more than doing this kind of work is watching someone doing it...
  #29 (permalink)
Old 06-12-2012, 09:10 PM
Ill post pics soon. Just had a baby girl. Been kinda busy
  #30 (permalink)
Old 06-12-2012, 09:39 PM
Congratulations. By the way, You are going to be busy for a while.
channeling a 54 chevy 210. 54Rat210 Body - Exterior 2 10-15-2011 09:03 AM
Big Block into a Chev 1954 210? Riot Racing Engine 9 08-04-2009 10:56 PM
1954 chevy 210 dash wiring skip47 Electrical 4 08-12-2007 08:21 PM
more castor from '55 chevy 210 mad55chevy Suspension - Brakes - Steering 3 04-20-2005 06:26 PM
53 chevy 210 wvbutch Introduce Yourself 1 01-20-2005 11:31 PM
