-   -   1954 chevy 3100 chassis upgrade (http://www.hotrodders.com/forum/1954-chevy-3100-chassis-upgrade-100386.html)
t.a.fuchs 10-16-2006 02:04 AM
as far as chassis upgrades i was just wondering about swapping in a chevy S-10 2WD standard cab long bed frame or what other options are available without cutting the frame in the middle and 4WD would be great too but not required, heavy half or 3/4 ton a plus and vehicle manufacturer not a concern.
Deuce 10-22-2006 10:08 PM
:D
This article is listed under the Wiki ...
check it out :thumbup:
It shows a Ford body swap but would be informative for your swap also .
www.geocities.com/lakota_circle_dancer/swap1
t.a.fuchs 10-26-2006 06:46 AM
1954 chevy pick-up frame swap
Deuce, thanks for the heads-up on the frame swap article, i read each and everything i can about what i am going to do, and i have learned a bunch, ADEngineering.com makes a kit using a 1980's vintage 2WD s-10 standard cab long bed pick-up because the wheel base is right on target and they offer a kit that looks better and better to me all the time, all the other s-10's extended cab etc. have different wheel bases and require more work, later, thanks.
tyman00 10-27-2006 09:09 AM
This thread has some good info on it.
http://www.hotrodders.com/forum/47-5...les-55537.html
That Ad-engineering kit is a tish on the spendy side, but when you consider the fact that you can have your body mounted on that frame in about a weekend... it might be work it.
