1954 Chevy Bel Air Engine is Stuck - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-29-2013, 08:33 PM
How dip I move the crank shaft?
Old 09-29-2013, 08:44 PM
techinspector1's Avatar
Wiki Edits: 326
Remove spark plugs. Mix 50/50 automatic transmission fluid and diesel fuel. Pour a cup full into each spark plug hole. Let sit a couple of days. Attach a long breaker bar (6 feet long) onto the crank at the front of the motor. Give the bar a tug forward and backward each day when you go past the motor. After a while, you'll begin getting a little movement. Keep after it until you get a full rotation.
Old 11-16-2013, 02:52 PM
4950fmc
54 stuck motor
Not sure on a 54, but on my 49 it's no big deal to drop the pan and do a visual.If you are lucky maybe you won't hurt the gasket and can reinstall the pan. The oil/trans fluid proceedure is a good one but if there is a serious rod or main bearing problem soaking it forever won't help. Had one like that! Good luck !
Old 11-16-2013, 05:00 PM
Wiki Edits: 27
stuck engine
I have a 472 Cadd in my saw mill. I should start and run it every year and the 6 trucks we have parked but I didn't, after the oil in the cylinders I pulled the starter and used a pry bar on the teeth on the flywheel and got it to move. and when I got it running NO smoke. Good caddy high nickle alloy blocks.
1954 Chevy bel air transmission meetdakota Transmission - Rearend 2 08-12-2013 12:44 AM
1954 Bel Air 2 door Sedan layin body on 22s sweeden Projects/Builds/My Ride 10 07-16-2013 02:37 AM
1954 Chevy Bel air meetdakota Projects/Builds/My Ride 5 06-30-2013 09:10 PM
1954 Bel Air Restoration gdstock Hotrodding Basics 18 11-22-2012 06:07 PM
53 Chevy Bel Air 454 engine 53Chevy509 Engine 11 03-21-2009 10:14 AM
