Thread Tools Search this Thread share on Facebook
  #1
Old 05-04-2009, 08:37 PM
Riot Racing's Avatar
Riot Racing Riot Racing is offline
Last journal entry: Wheels were sandblasted
1954 Chevy inline 6 (235cid) engine specifics
Guys I am developing a model fot he chevy inline 6 engine for a project at school. I am going to run an engine simulation to determine certain performance factors and possibly some emissions values. I'm short on time so I need some quick values for the stock engine.
I need to know the intake port size. But I need the diameter size of all the junctions. So this would be the intake port then the run diameter leading to the intake port, then the diameter of the y junction for the two ports.
I need these same values for the exhaust side.
I know this might be asking for a bit much but: what about the radius sizes on these manifolds
Internally: I need the connecting rod length
and clearance height
Is it safe to assume the wrist pin offset is 0?
I searched and even emailed some engine companies to try and obtain these values but had no luck.
Register now (free) or login to remove ads
Old 05-04-2009, 09:01 PM
matt167 matt167 is offline
Wiki Edits: 31
your better off using a diffrent engine.. I might be able to give you the connecting rod length, deck height and piston pin offset and valve size, but that's it.. I'll have to check my manual ( '53 Motors manual ).. the other stuff you need, nobody is going to have, and my book deffinatly doesn't have it
Old 05-05-2009, 10:11 PM
Could you please get me those values? I will take my intake manifold and exhaust manifold off and Ill just measure the orfices myself.
Old 05-08-2009, 02:00 PM
Wiki Edits: 31
I don't have connecting rod length, pr pistion pin offset like I thought I had, but I'll give you what I got... valves are 30* intake 45* exhaust .3413 int .3403 exh
Old 05-08-2009, 02:05 PM
Jmark's Avatar
Jmark Jmark is offline
Wow, you are asking for a lot of info that GM probably doesn't even have anymore! LOL And you need it all yesterday? Looks like you'll be doing a lot of "fudging" on numbers in your spread sheet program tonight! LOL.
Mark
Old 05-08-2009, 11:39 PM
Mark
HAha. Ive moved onto a different engine that I have info. Yamaha R6 fo a 03-05 engine.
We use them in our race cars all the time
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "1954 Chevy inline 6 (235cid) engine specifics"
ThreadThread StarterForumRepliesLast Post
the history of chevy v8'ssavman1Hotrodders' Lounge4303-02-2012 06:57 PM
Has anyone adapted a Mopar trans to Chevy engine?383ramTransmission - Rearend2605-19-2009 04:31 PM
Chevy 505 Mark IV Engine?71gtxEngine504-06-2009 03:44 PM
pontiac engine to chevy tranny...markzepp820Transmission - Rearend703-13-2009 08:49 AM
Cam Helpblack66Engine305-12-2003 06:15 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
