1954 Desoto Firedome Hemi wiring schematic needed - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-02-2013, 10:15 AM
hduff's Avatar
Fix it until it breaks
Last journal entry: Matt got a new motorcycle.
I'm in need of a wiring schematic for a 1954 Desoto Firedome Hemi that just arrived at the shop and has some serious wiring issues.
Does anybody have a schematic, links to one, or a resource for one? I don't usually do restoration work (or work on cars this "new"), so I'm at loss for now.
Old 07-02-2013, 10:51 AM
Banned
2 second google search.
Name:	54 desoto.jpg
Old 07-02-2013, 12:03 PM
hduff's Avatar
Thanks. I've had such poor luck using Google to find obscure car stuff like this I had given up long ago.
But a close check reveals that diagram is for a 1949 Desoto Six, so still looking.
I did find
this link this link
to a factory service manual.
Old 07-02-2013, 12:35 PM
Banned
ok try this one out.
1954 1955 DeSoto Shop Service Repair Manual Book Engine Drivetrain Electrical OE | eBay
Old 07-02-2013, 12:47 PM
hduff's Avatar
[/url]
Same book; just ordered it from Amazon for a few bucks less.
What I'm dealing with is an original wiring harness that has been modified and repaired over the past 60 years and it is now difficult to tell OEM from "modified".
And of course, it's all a crapfest of jumpered and spliced wires. he starter barely turns (with a charged 6Vbattery), half the lights don't work and there's a short somewhere. If this was not for a friend, I would be running the other way.
Thanks for your response.
Old 07-02-2013, 01:47 PM
Joe G's Avatar
It's not too often that I work on something that new either. The newest DeSoto wiring diagram I have is for a '53. but hopefully it will help.
Good Luck....
Old 07-02-2013, 02:00 PM
hduff's Avatar
Good Luck....
Thanks. 53/54 were very similar. I can already see how somebody farked up the starter relay: both heavy cables are attached to the same stud. I suspect that was their "fix" for a bad soleniod.
This won't be pretty.
Old 07-02-2013, 04:02 PM
techinspector1's Avatar
Wiki Edits: 326
Begin by grounding the body to the frame and the frame to the motor. I know you know this, just reminding you not to begin running wire until you have the whole mess properly grounded.
Old 07-02-2013, 04:57 PM
hduff's Avatar
I just replaced the very deteriorated battery cables and cleaned their connections to the motor and starter relay; battery is now fully charged (but disconnected). Next I'll get it up on the lift, clean and check the connections at the starter and the grounds to the body frame, hook the battery back up and take some measurements to check on voltage drop, then check starter and generator performance.
The car was last actively driven in 2000, so that was probably the last time it was serviced, so once I get it to turn over, I'll change all the fluids.
It is a thrill to be working on an original Hemi car.
Old 07-02-2013, 05:09 PM
Banned
ok i like to help out but this car was last actively driven in 2000 . Then your other post about paint says it was painted 4 years ago. does not add up too me. am i missing something?
Old 07-02-2013, 06:02 PM
hduff's Avatar
The car was repainted for her dad just before he passed away. He took it for a few spins around the block and then parked it. The car has not been routinely (that might be a better word) driven since 2000 when her dad got too old to drive regularly.
Other than the Hemi, the car's not worth much, certainly not worth doing a full restoration. I'm just try to get the car back to running condition so it does not become junkyard fodder. That may ultimately be pointless, but the car has great sentimental value to my friend and her siblings.
Desoto, Chrysler, Dodge Hemi parts interchange moparjoe Engine 8 12-20-2010 08:59 AM
desoto firedome 331 tom331 Engine 3 06-24-2009 07:43 PM
info about desoto hemi carb. boggla500 Engine 6 04-15-2007 09:00 PM
Desoto Hemi ,please Help!! B.W.C. Engine 5 04-27-2006 12:54 AM
Looking for 69 Camaro wiring Schematic alittle1 Electrical 0 08-05-2003 04:25 PM
