1954 merc project. Mii or subframe? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-29-2007, 07:39 PM
62galaxiguy's Avatar
Hi i ve got a 54 merc 2 dr ht i just got and want to update the front susp.Im building a mild kustom and want to go with a sbc and gm a/t with front discs.What would be easier/better?. A subframe swap or go with a Heidts Mii kit? Thanks.
Old 09-29-2007, 08:43 PM
Wiki Edits: 31
Check the wheelbase/ track width of a '90's Crown Vic/ Merc Grand Marquise. I'm pretty shure it would fit under the '54 Merc with little trouble. you could easilly sell the 4.6/ tranny for a little recovery money, and bolt in a SBC/ TH350 fairly easy.
Old 09-29-2007, 08:51 PM
What about front
sheetmetal mounting,core support,etc.What would be easier ll frame swap or mii.? What about cost ?
Old 09-29-2007, 09:06 PM
Wiki Edits: 31
depends on the MII kit price. it would probably be like $2,500 or so for a complete MII kit, should be able to just get the correct MII X member, and put it togther peice by peice, but I'm not shure on cost diffrence.
with a frame swap, such as the Crown Vic, the cars can go in the ballpark of $800 if you, I know person who bought 3 for that price.
You would have to weld in new body/ sheetmetal points, and rework somthing for the core support, but that's pretty much it. The Crown vic frame is almost like a 2"x3" boxed frame. you would gain laddar bar/ trailing arm rear suspension, 4whl disc brakes, and a Ford 8.8" rear end.
ither 1, there is welding involved.
Old 09-29-2007, 09:07 PM
brian0605's Avatar
mostly confused
Last journal entry:
Take a look at the 54 ford I have posted in my photo album. We have already installed a SBC and 700r4. We used the stock steering and suspension. It drives quite well. No it's not a Lamborghini, but they sell a sway bar that you can put on the rear suspension and a upgrade for the front sway bar. We haven't gotten those parts yet but will in the future.We used the factory installed 54 power steering and a GM Power steering pump with a flow/pressure reducer.There is a lot of work involved in changing the body to another chassis . If you decide to keep the stock suspension and use a SBC and automatic. Send me a private messange and I can give you the exact details of how to install it. Lots of work went into making it all work correctly. Good luck with whatever you decide. Brian
Old 09-30-2007, 01:37 AM
Chopt 48's Avatar
I swapped a first series Camaro (also 68/72 Nova stub) with the Rear steering box in to my 51 Merc about 30 years ago with great luck. I know the 52/53 frames are a bit different but they may pretty close to the same.
With a bit of trimming the Merc frame rails slid right over the Nova subframe and the back tips of the subframe tied into the Merc X member with just a bit of trimming. The core support came down inline with the front cross piece of the subframe and bolted on with a just a couple of small spacers.
The Sub frame rode at stock hight while the body sat at the correct low height.
This was due to setting the subframe on a block the same height as the crossmember clearance on a stock Nova. The Merc was sitting blocked up at the final height that I wanted it to sit at. With measuring, trimming an leveling we got it tacked together in a couple of hours to where we could bolt the wheels back on and roll it to a better location for final welding and a couple of boxing plates. There were the usual tweaks to do but the final product was a great driving car that would cruise at 80 comfortably.
I don't remember if I took any photos when we were doing the swap but I will check my box of old photos.
We put in a late model tilt column with little effort and ran a 70 something GM booster and Master Cylinder along with the 72 Chevelle disk brake setup.
I would shy away from complete frame swaps as a lot of the structural strength of the early cars was in the X member of the frame and the floor boards don't have the built in extra strength pieces that the later cars have.
Also most Fords have a front sump oil pan that sets in front of the crossmember and the crossmember will interfere with the Chev pan.
Measure the width of your frame rails about 2 inches behind the mounts for the control arms or at the first place the rails are straight close to that and then measure the width of a Nova subframe in the same area.
The custom front suspension setup would be nice if you are willing to spend the money though.
Old 09-30-2007, 10:16 AM
Youngster's Avatar
1954 Merc project
I don't know how much time or money you want to put into your Merc, but if it was me, I'd give brian0605's offer some real serious thought.
Youngster
New project? Before turning a wrench, get organized! Centerline Hotrodding Basics 71 03-10-2013 12:29 PM
The Car Music Project: garage band with instruments made from an old Honda hoodoo Hotrodders' Lounge 0 07-22-2005 01:08 AM
New Site Feature: Project Journals Jon Hotrodders' Lounge 8 01-08-2005 11:10 AM
ATTN: Project of the Week Submitters Jon Hotrodders' Lounge 3 04-22-2004 01:04 AM
Thanks to Project of the Week submitters Jon Hotrodders' Lounge 0 12-06-2003 11:23 AM
