1954chevy 3100 halfton - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-29-2012, 03:10 PM
how can u put the radaitor in after u put a 1973 camaro front clip on the truck
Old 02-29-2012, 04:12 PM
You have to fabricate some brackets to bolt the radiator core support to. It's going to need to be just in front of the steering gear box so the cut to the camaro frame will be there somewhere. The best way is to hang your front fenders and core support on the cab using the upper and lower fender bolts. Block it up in the front so the body lines and door gaps are straight. Make sure it is centered by cross measuring from inside the hood area. THEN...there are two ways. Fabricate your own mounts like I did or cut the front off the original frame where the core support mounted and graft it on the camaro clip. The advantage of number 2 is it also gives you front bumper mounting spots if you use the stock bumper. I'm using a custom bumper so I made my own doing exactly what I outlined above. Mine is on a 55 but the steps are the same.
ID:	63496   Click image for larger version
ID:	63497   Click image for larger version
454 going into my 53 3100 chevy53 Engine 10 01-18-2013 09:24 PM
need help rebuildin eng for 57 3100 zenchal26 Hotrodding Basics 7 11-26-2011 10:34 AM
IFS Install, 51 3100 slstusmc Suspension - Brakes - Steering 3 07-24-2006 06:22 PM
51 chevy 3100 raven51 Transmission - Rearend 4 03-23-2006 06:17 AM
53 3100 flyfish Introduce Yourself 3 01-26-2006 08:01 PM
