1955 2nd series body to 70's/80's p/u frame - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-07-2008, 10:07 AM
I was wondering is it is possible to put my 55 2nd series body on a 70's to late 80's frame? i have heard that the frames slide together when doing a "front clip" and before you ask the frame is not in good shape thats why i want to swap. and the bonus being it stays chevy any help would be greatly appreciated
Old 11-07-2008, 10:29 AM
The Maintenance Geek
Unbolt the front suspension of a mid '70s Chevy pickup, and it
falls out on the ground, you'll need the front sections off the
frame to set the steering box and drag link in the right places...
Should be fairly straight forward...
K
Old 11-07-2008, 05:36 PM
frame
i would like to place my 55 body on a 70's to 80's frame is it possible witouot major headaches?
Old 11-08-2008, 08:08 PM
57halfton's Avatar
NO, not with out major headaches. The later chassis your thinking of are wider, 2 wheel drive front track width is to wide, if your thinking 4x4 then yes it will work.
Gene
g body frame notch sheldonw Suspension - Brakes - Steering 2 03-14-2008 09:37 PM
body change to later frame streetrod936 Suspension - Brakes - Steering 11 12-15-2005 08:44 AM
No body for my frame Bandito General Rodding Tech 3 03-23-2003 12:38 PM
'74-'77 Corvette body on an A body frame blaileigh Suspension - Brakes - Steering 0 02-01-2003 08:32 PM
31 ford 5 window coupe body and frame krzycat Body - Exterior 0 12-14-2002 08:00 AM
