1955 Bel-Air differential ID numbers? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-26-2012, 01:55 PM
I have a rear end with this #A210 3725899 Gm-16. I would like to know if anyone knows what these numbers tell me about my rear-end.
Old 08-26-2012, 02:02 PM
Crosley's Avatar
Wiki Edits: 1659
welcome to Hotrodders.
I edited the thread title so the membership has an idea what your specific question on the 55 Bel Aire is
Old 08-29-2012, 06:54 AM
SSedan64's Avatar
Those are only Casting ID numbers, they wont give you the Ratio or Carrier type.
Differentials: GM 55P - Drop out style rear end with no removable pinion support. Uses bolt in axles. Has 8.2 ring gear. Ring Gear Bolts: (10) 3 8 x 24 RH
Look on the passenger side axle Tube for stamped numbers. Wire brush or wheel will come in handy.
General # location Pic >> Reference Manual: Chapter 3: Axles: Factory Useage
end, rear
Air Ride on a 1953 chevy bel air LowClearanceCustoms Suspension - Brakes - Steering 1 10-16-2008 03:40 PM
stealth cool air intake system for 55 Bel Air Berliner Bel Air Engine 9 11-30-2004 03:32 PM
GM 8.2 differential bearing numbers? ken47 Transmission - Rearend 0 11-11-2003 01:29 PM
1955 Differential Replacement opinionated Transmission - Rearend 2 08-29-2003 07:00 PM
1955 Bel Air wiper trouble Devon Body - Exterior 1 10-26-2002 05:18 PM
