1955 Chevrolet 3200 lowering - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-07-2005, 04:51 PM
bowtiebadboy's Avatar
first timer
Hi,
Heres the deal i want lower my truck(1955 Chevrolet 3200) and i have 125 dollars (welding and cutting is not a problem) to do it. If anyone one has any ideas please let me know.
thanks
Tyler
Old 05-08-2005, 08:02 AM
jalopy45's Avatar
If you want the old school way it would be flip the axles to sit on the springs, the rear is the easiest, just weld new perches on the bottom(make sure to keep your pinion angle correct) and for the front fabricate some u-shaped perches that go under the axle with register holes and up to the original spring perches. take a flat piece of plate with a nut welded to it that fits in the original spring register hole and weld the ends to the new u-shaped perches so that it forms a box around the axle. I would recommend new u-bolts and you should be under $50. Will still ride like a pick-up but you will look kool.
Rods Built By Owners(RBBO)club member
wrecking yard archeologist
Old 05-09-2005, 09:26 PM
first timer
thanks i might try it this weekend
on line manuals wy.miner Hotrodding Basics 12 05-08-2005 10:42 PM
Parts Indentification Manuals question JhnBrackett Hotrodding Basics 1 12-01-2004 12:02 PM
Lowering a 1951 Chevrolet pick-up Rebelson Body - Exterior 6 03-12-2003 09:01 AM
Whatever happend to these guys? hot_rod_kid Hotrodders' Lounge 20 12-17-2002 10:20 AM
54 chevy ? pichoboxing Hotrodders' Lounge 11 07-29-2002 07:32 PM
