1955 chevy with a 75 GMC IFS disc brake help - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-08-2009, 09:51 AM
machinist & fabricator
i got a 55 chevy panel van that i just did a IFS swap on...
the IFS came out of a 75 GMC 3/4 ton pick up.
i utilized the master and proportioning valve off of the 75 pick up as well...
i mounted the master cylinder underneath the floor board, but not lower than the brake cylinders/calipers.
when i finished it, the front brakes would hold some pressure after i let off the brake pedal.
i went throu everything and found that the brake pedal rod was not letting the master cylinder return to its original position.
i fixed that and it seemed fine.. brakes felt perfect, and when i let off the brakes, the calipers would let off as well..... this was yesterday about 5 pm
this morning, i got up to take my kid to school. and as soon as i hit the brake pedal, and released it, the brakes would slightly grab...
i thought it could be the master cylinder boiling over, but the temp gauge hadnt even registered... ( i didnt warm the truck up)
i know that residiual valves are for instances where the master cylinder is mounted lower than the brake cylinders/calipers.... i dont think i need them, for they dont let pressure bleed back into the master..
and ive never heard of a porportioning valves going bad.....
could it be calipers?
its only happening in the front....
ANY IDEAS?
Old 01-08-2009, 03:33 PM
Are you using the 55 or 75 master cylinder?
Shane
Old 01-08-2009, 03:58 PM
im not that dumb man!!!
well 50% i guess...
on the 55 master, its also the mount for the brake pedal.
so took the piston out, and made it hallow to house the new brake pedal rod.
i have a new 1975 chevy master cylinder mounted behind that.
without the power booster.
i talked to my parts guy, and he said it might have a checkvalve in the front resivor that shouldnt be there.
ill have to check on that after work.
thanks for the post tho!
63 impala front disc brake conversion derwood3 Suspension - Brakes - Steering 6 12-27-2012 05:04 PM
Ford Galaxie Disc Brake Conversion CrashFarmer2 Suspension - Brakes - Steering 5 04-10-2010 04:52 PM
drum to disc conversion kits dmented Suspension - Brakes - Steering 4 06-06-2007 09:06 PM
Disc Brake Conversion 1961 Chevy Truck monteman70 Suspension - Brakes - Steering 5 06-01-2004 08:09 AM
57 Chevy Disc Brakes.. CHEAP PLEASE 30chevycoupe Suspension - Brakes - Steering 4 05-04-2004 09:17 AM
