1955 chevy HEI - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-02-2006, 09:40 AM
1955 chevy HEI
Iam working on a 1955 chevy Bel Air and I am going to put a 350 in it with a HEI. Was wondering if the motor should be mounted forward alittle bit to give me some more room?
Old 03-02-2006, 10:40 AM
Big Block Z28
I wouldn't go through all the trouble to move the engine forward just for the HEI. (I installed a late 70s HEI in my '70 Z28 and it cleared with no problem.) If there is a clearance problem you can get an aftermarket distributor that has a smaller diameter like the early Chevy non-HEIs.
Old 03-02-2006, 10:50 AM
Stroker56's Avatar
I had to move mine forward in my 56 sedan with a stock 70's dizzy
3/4 of an inch did it
Old 03-02-2006, 04:05 PM
bowtienut's Avatar
if you run the stock HEI in the old shoebox cars it can come in contact with the firewall if your motor and tranny mounts are not in excellent shape, I butsed two caps on my double nickle going over the train tracks near my house. I then converted an old points type distributor to HEI with the petronics(not sure about the spelling) kit and presto....no more problems and it works very well, good luck.
Old 03-02-2006, 06:04 PM
302 Z28's Avatar
I would just relieve the firewall to gain the required clearance. It can be done so it looks factory if you are careful.
Vince
Old 03-02-2006, 08:26 PM
57 Chevy's Avatar
Yep, HEI won't fit with stock motor location. Move it forward, everything else needs to come forward too. Bend the firewall, it ain't easy. Early dist. with electronics inside is the easy way. It's your choice on how much work and headache you want.
looking for stock-type snorkel air cleaner to fit 1955 Chevy Berliner Bel Air Engine 5 09-15-2011 08:32 PM
HEI Distributor for Chevy 216? fastback49 Electrical 2 06-05-2005 02:00 PM
1955 chevy 235 cam thrust plate captjosh Engine 1 05-26-2005 01:27 PM
Transmission Identification? 1955 Chevy Truck chrome_ashes Transmission - Rearend 0 11-25-2002 01:52 PM
1955 Chevy Pick Up, Wheel rear spacing? Alf Transmission - Rearend 1 09-19-2002 07:02 PM
