1955 Chevy horn - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-10-2007, 05:01 PM
1955 Chevy horn
i purchased a 1955 Chevy last week. the 55 has a Grant steering wheel and an Ididit steering column. The first owner of the 55 never setup a horn on the car. I purchased a horn/relay kit, how do I wire it up ?
There is a wire from the horn button down into the steering column, that is all I know about that.
Thanks, My55
Old 08-10-2007, 09:54 PM
docvette's Avatar
Wiki Edits: 12
Thanks, My55
Doc here,
Traditionally, A horn will wire like this:
The horn button wire down to the relay coil ground # 85...
Relay power from any Fused (about an amp..) BATT source..terminal #86
Power from a fuse link and the battery to the relay CONTACT # 87, use a 10 gauge wire here..
Horn output wire goes to Relay CONTACT # 30 , use a 10 gauge wire here..
Relay contact 87a is not used for this application.
That's it...simple as pie!
Doc
Old 08-11-2007, 01:31 PM
Thanks........
Is there a way to tell if the wire from the horn button, is really wired up and is coming out of the steering column ?
Old 08-11-2007, 02:07 PM
docvette's Avatar
Wiki Edits: 12
Thanks........
Doc here,
Get out your DVOM, set it for Ohms, ground one probe to the column and the other to the wire..it should read infinite until you push the button..then "000"..It's connected.
Doc
Old 08-11-2007, 03:30 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
An Ididit column uses a GM turn switch.
The black wire in the TS connector should be the horn wire.
This is the wire to check for grounding when the horn button is pushed.
Might want to check continuity from the exising horn relay (is there one?) to the switch connector and on up into the switch.
Old 08-12-2007, 08:52 AM
this will help alot
go to this link. it is my understanding that all from 1954 to 1958 same thing. skhttp://www.1953chevrolet.com/1953_Chevrolet_Techinfo.htmip47
What's the best carb & fuel tank replacement for a 1955 Chevy 235 straight six? islandman Engine 5 09-17-2011 10:50 PM
My 1955 Chevy lifelong upkeep and restoration Tommy T Introduce Yourself 1 07-26-2007 01:38 AM
1955 2nd Series Chevy Truck Returns Home TaskForce55 Introduce Yourself 2 08-22-2006 01:28 PM
Transmission Identification? 1955 Chevy Truck chrome_ashes Transmission - Rearend 0 11-25-2002 01:52 PM
1955 Chevy Pick Up, Wheel rear spacing? Alf Transmission - Rearend 1 09-19-2002 07:02 PM
