How much for sub frame, video etc. What all is on the sub frame?
I payed $300 for the sub frame a few weeks ago and bought the video for around 40 bucks I think. I would like to get my $300 bucks back and will throw in the video. The sub has everything except for the power steering box as far as I can tell.
I can be contacted via e-mail at jeffhickl@earthlink .net or office 281-441-9595 home 281-572-2420 thanks Jeff Hickl |
Oh yeah, I had already cut the frame in accordance to the video. If you plan on using another method, it may pose a problem. If you do it the "nolimit" way, it will be good to go.
Thanks Jeff |
56 project
any photos on subframe being mounted on 56 pick up
56 project
i am just learning this computer thing where do i go to see the video
56 project
hey jeff
i am new on this computer stuff just learnin how do i see the video you are referring to robert |
56 project
hey jeff
i already have the subframe i am looking for the video on installing it on my 56 chev pick up robert |
Subframe
I have also grafted a transam subframe to my 57 pickup. the question I have is how did you mount the radiator support frame to the clip? Did you cut the subframe tips? I am also having problems aligning the front fenders with the front of the clip. any help would be greatly appreciated.
| The Following User Says Thank You to willys36@aol.com For This Useful Post: | ||
Jaochoa (08-28-2012) | ||
Thanks willys36, I still have the orignal frame and the tabs for the radiator support.
While I would admittedly go with the Mustang II crossmember, lots of folks have done the subframe swap. Make sure, and I repeat, make sure that you do lots of measuring before making any cuts, regardless of what subframe you are using. Once you cut your original front frame off, there is no going back. Also, give some thought as to how you are going to mount front sheet metal, radiator, and other stuff like that before you cut off the front half of your truck frame. I'm not trying to talk you out of it, just want you to be a success.
Dennis W. Parks Author of automotive how-to books |
