Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1955 chevy wheel alignment
Old 03-03-2006, 10:16 PM
pepi's Avatar
pepi pepi is offline
How’s that hopey-changey thing
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
not being a front end guy, however I would be thinking yes, the only thing changed was the brake components. You did not indicate the alignment problem you are seeing, if you disconnected the drag link you might have moved the adjustment that way. I am making the assumption that you are talking toe in/toe out, out of whack. Certainly the caster and camber were not affected by the brake upgrade.
