-   -   1955 chevy wheel alignment (http://www.hotrodders.com/forum/1955-chevy-wheel-alignment-83217.html)
cherry55 03-03-2006 09:35 PM
I just converted to Front disc brakes and the alignment is way out of whack. To realign the front end do I use the original specs?
pepi 03-03-2006 10:16 PM
not being a front end guy, however I would be thinking yes, the only thing changed was the brake components. You did not indicate the alignment problem you are seeing, if you disconnected the drag link you might have moved the adjustment that way. I am making the assumption that you are talking toe in/toe out, out of whack. Certainly the caster and camber were not affected by the brake upgrade.
cherry55 03-04-2006 05:34 PM
wheel alignment
Hi Pepi
yes, I have serious toe in. I wasn't sure if you used the original specs. They are different if you use a 605 steering box.
Thanks,
Bill
N.Y.
57 Chevy 03-04-2006 07:30 PM
Disc brakes increase the tread width about 5/8" or more. Thats why your toe is off. Reset the toe back to stock. The caster and camber didn't change. Adjust each side equally.
cherry55 03-04-2006 08:47 PM
Thanks guys(pepi, 57 chevy) I appreciate the help.
Bill
N.Y.
pepi 03-04-2006 10:14 PM
glad to have helped
