1955 Customline with 351 Windsor C4, Stock rearend strong enough? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-07-2012, 09:01 PM
I just purchased a 1955 Customline with a 351 Windsor c4 Transmission, was wondering if the stock rear end will handle this. And was wondering what rear end it is originally? Any advice would be appreciated. Thanks this car is also a 4 door.
Old 07-07-2012, 09:28 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Welcome to Hotrodders.com
I edited the thread title to provide some information on your question.
We dont use ''help or help please'' in thread titles. A proper thread title helps the members and the search function on this website
Old 07-08-2012, 06:39 AM
Irelands child's Avatar
If indeed that rear end is the stock 'as supplied' by Ford in 1951, it will survive only if you are gentle. It was built to handle 239 ci, 100-110 Hp and 150-160+/- lb ft of torque all put to the road on skinny 'un' grippy tires. In my distant past, I was able to destroy several with just a warmed over flathead and even more when I went to a 312 ci 'Y' block - but they were cheap then and I always had a couple spares along with at least one transmission. Minimum I would consider would be a Ford 8", even better a 9" of a good width and ratio. An 8.8" might be an even better choice, along with the disc brakes.
Irelands child
Old 07-08-2012, 05:36 PM
big gear head's Avatar
High Performance Rear Ends
I don't think it's going to hold up very well. I don't know where you are, but I've got a '57 Ford 9 inch that would probably bolt in.
Old 07-11-2012, 10:17 AM
Hot Rod Has Been
Station wagons had a Dana 44 which has been used in billions of cars and trucks over the years and parts are readily available.
The sedan rear is a Ford design, has a drop out center section and 12 spline axles. It will hold up as long as you don't dump the clutch and do burnouts everyday. You will likely break an axle if you install wide, sticky tires and drive it hard.
There are a few guys around town here that have '55/'56's with the Ford-style rears behind 390's and have never had a problem... and they built these cars in the 60's. But they don't beat the crap out of 'em either.
I'd run it until it breaks... then switch to a 9 inch.
351 Modified vs. 351 windsor vs. 351 cleavland ? Blackbob Engine 78 01-27-2013 05:15 AM
1955 ford customline 272 yblock ronniemoon Hotrodding Basics 5 06-24-2012 10:45 PM
1955 Ford Customline restoration company? AK55 General Rodding Tech 1 07-05-2011 10:43 AM
351 Windsor: minimum 350+/350+ with stock crank,rods and heads? BB72R-Yes Engine 5 07-20-2010 09:18 PM
Chopping a 1955 Ford Customline someone help me PLEASE Body - Exterior 10 04-10-2007 04:01 PM
