1955 ford customline 272 yblock - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-12-2012, 08:48 PM
I did a motor swap on a 1955 customline i put a 272 y block from a boat it spins over but dosent start.
Old 06-12-2012, 10:43 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Do you have power to the coil and spark to the plugs? Fuel when you open the throttle? Have you messed with the distributor/timing?
Semper Fi
Old 06-13-2012, 07:59 AM
1955 y block 272
I replaced the orig. motor with a 272 from a 1955 boat I was told that the engine turns in reverse after i had put it in what do i need to do.
Old 06-13-2012, 11:58 AM
The cam must be repaced with a "conventional" one. Melling offers a "stock replacement', part no. SYB-2. There may be some "performance' grinds out there.
The distributor gear will also need to be changed to the "conventional" one.
Jim
Old 06-13-2012, 01:39 PM
WDCreech's Avatar
Grumpy Old Goat Herder
Jim
Also, You must have a starter that spins in the right direction.
Bill
Old 06-24-2012, 09:45 PM
Boat engine
Was this a full fledged boat motor with the aluminum front cover, twin side draft carbs, wet exhaust etc? They also have a valve cover oil fill which is unusual for automotive Y-blocks. The counter-rotation version had a gear drive camshaft with no chain - you would have seen it if you had the front cover off.
Chances are - its an air/fuel/spark thing........
1955 Ford Customline restoration company? AK55 General Rodding Tech 1 07-05-2011 09:43 AM
1955 Ford Customline Brake Conversion 61fleetwood Suspension - Brakes - Steering 2 02-24-2010 12:22 AM
272 customline swap 55customline08 Engine 1 04-11-2008 12:35 AM
Bad Steering Box 1955 Ford Customline Sweet-34 Suspension - Brakes - Steering 7 08-27-2007 02:32 AM
Chopping a 1955 Ford Customline someone help me PLEASE Body - Exterior 10 04-10-2007 03:01 PM
