Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1955 Headers & 500 CPP Steering Box
Old 01-09-2013, 08:07 PM
327NUT's Avatar
327NUT 327NUT is offline
Keep researching, I have used 2 sets of Sanderson's and even though they are very heavy duty parts they are waaaay overpriced and the insides of the ports at the flange are some of the worst I've ever seen. In order for them to surface grind that area so you don't need to run a gasket (as they claim) they build up a huge amount of weld. Once it's ground down flat the port is full of nasty left over weld that they don't grind out. Take a look before you buy.
