1955 thunderbird auto. transmission fluid - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 07-22-2007, 05:23 PM
Originally Posted by rick laplante
thank you all for the help i am not sure where to post this next question if some one could tell me i will post it, it has to do with hanging a 6 volt alternator on a 292 engine i am trying to hang it on the org. bracket but have some mod's to make to make it work. any idea's ?
stay with the generator,if you have gone to the trouble of staying stock a alternator looks like crap. also pre lube the engine be for startup. i would go with 10 30 oil and the gm aditive. remember if the 292 has the original distributor you must use original teapot holley as you have no centrifical advance, vacume only later carbs have incorect vacume signal for 55 distributor.
  #17 (permalink)
Old 07-22-2007, 06:13 PM
redlightning's Avatar
http://www.ranchwagon.com/tech/alt/alt.htm
I found this link a while back.When I get my 56 on the road I am planning on giving it a try.
  #18 (permalink)
Old 07-23-2007, 02:17 AM
aka Duke of URL
...it has to do with hanging a 6 volt alternator on a 292 engine i am trying to hang it on the org. bracket but have some mod's to make to make it work. any idea's ?
Will the below setup help?
Name:	YBLOCK ALT Mounting Kit C.R.A.P..jpg
  #19 (permalink)
Old 07-23-2007, 06:17 AM
Last journal entry: done as of 9/10/08
i sent for one of them and it did not work it came out to far ( to close to the front sup.) i asked him if he had one that was a little closer to the engine but he did not have one.
he said he was working on one for a 55 thunderbird but never heard from him again. tried to contact him but no response
  #20 (permalink)
Old 07-23-2007, 09:31 AM
a source for bird help,
http://www.larrystbird.com/index.php3
30 years + doin' birds.....
use the contact page to order the catalog and describe your fit problem
"plan B"=there are much smaller alt available from the imports
(friggin' CRS!)....I swear I've seen a alt that is built to look just like the original generator to keep the factory look and mount and can't recall from who
here's another helpful link....
http://www.ctci.org/
a ton of early bird specific info, here's an example (look under Gil's garage for 6V to 12V convert):
http://www.ctci.org/membership/memindex.htm
  #21 (permalink)
Old 07-23-2007, 10:21 AM
(geeze...I surprised myself by remembering)
rick,
it's Powermaster that makes the alt that looks like a generator.....
here's the link
http://www.powermastermotorsports.com/powergen.html
  #22 (permalink)
Old 07-24-2007, 09:08 PM
http://www.y-blocksforever.com/
http://www.y-blocksforever.com/tech/
http://www.y-blocksforever.com/forums/
Rick, The above site also has some good Y-Block info.
  #23 (permalink)
Old 07-26-2007, 07:41 AM
sorry it took so long to reply but my net was down hope they can keep it up now.
i would like to thank you all for the help i am learning more here than any place.
i can use all the help i can get again thank you
rick
Type FA transmission fluid 406chevelle Transmission - Rearend 6 03-15-2005 08:03 PM
Transmission Fluid c-4 85stangboy Transmission - Rearend 9 12-21-2004 07:15 PM
Transmission Information. M&M CUSTOM Transmission - Rearend 1 08-24-2004 03:15 PM
Transmission swap - Auto to Manual Croz Transmission - Rearend 2 03-09-2004 03:34 PM
Manual or Auto transmission? '54-Hunter Hotrodders' Lounge 20 01-12-2003 08:07 AM
