Can you just change the upper control arm shaft and get enough caster to do any good, I dont have a problem changing the control arms if I need to, I just dont particularly care for how they look. I am useing a 500 box from CPP and a Tilt wheel from them as well. I have everything new to re-do entire front end, but I dont want to rebuild the Stock Upper and lower control arms with bushings and ball joints and then end up putting New Style control arms on anyway. So any input will be appreciated. PS: I am running radial tires on 15X7 rims. It drives fair on a smooth road but if not its hunting a place to go so this is why I am changing everything to power steering and useing the 500 box.
