1955 truck 6 cylinder front engine mount bolts - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-27-2012, 06:02 AM
I'm restoring a '55 Cameo for my friend Robby, his brother did the disassembly years ago, and we can't find the original front mount bolts, I understand they are a different length than the V-8's. Does *********** someone have dimensions and a picture so I can make replacements on my lathe? I really don't want threaded rod with ny-lock nuts here. thanks in advance karl********************cell
Last edited by 68NovaSS; 12-27-2012 at 02:31 PM. Reason: Classifieds, email or phone numbers not allowed in forums, see board guidelines
Old 12-27-2012, 11:14 AM
hcompton's Avatar
Old & Furious
Originally Posted by specialty motor cars View Post
I'm restoring a '55 Cameo for my friend Robby, his brother did the disassembly years ago, and we can't find the original front mount bolts, I understand they are a different length than the V-8's. Does *********** someone have dimensions and a picture so I can make replacements on my lathe? I really don't want threaded rod with ny-lock nuts here. thanks in advance karl ************* cell
Not sure but you could try to buy them as nos but i dont think they will be easy to find. Do you have a can of cylinder head bolts laying around? I bet one of them will be close. You can also try to weld nuts inside the mount and use two factory style bolts. Even on a clean restore it would be hard to spot. Make sure they are not going anywhere but should work if closed style mount. Open mounts you will be stuck finding the correct bolts or making somthing work.
Longest shoulders on most bolts are the mounts and head bolts. Can you maesure how long they would need to be. Some of the guys on the sight have lots of knowledge on parts and chevy tries to reuse every nut and bolt over and over again so they may just be a standard bolt.
Old 12-27-2012, 05:55 PM
this would be the bolt I need goes between the rubber bushings on both side of the engineClick image for larger version
Old 12-27-2012, 06:15 PM
hcompton's Avatar
Old & Furious
This is for most chevy cars in 55 they have the same part listed for both engines.
Chevy Engine Front Mounting Kit, 6-Cylinder & V8, 1955-1957 - Eckler's Classic Chevy Parts
I am not familar with the cameo maybe i am just having a brain fart right now been a long day.
Hope this helps.
Old 12-27-2012, 06:21 PM
hcompton's Avatar
Old & Furious
Here this looks right if the reproduce the mount they will usally sell a bolt kit. The price stinks sorry first one in google. All else fails lookup the company that makes it and ask for replacement bolts Sometimes works.
Truck Chevy Truck Engine Mount, Front, Small Block, 1955-1959 - Eckler's Truck Parts
front top shock mount 59 chevy truck jhatch43 Suspension - Brakes - Steering 1 02-10-2012 11:33 AM
1955.2 Chevy Truck LS1 Front Ford 8.8 Rear 4 wheel Disc fasteddy51 Suspension - Brakes - Steering 1 07-13-2011 03:16 PM
1955 Chevy truck shock mount miamichevytruck Hotrodding Basics 6 04-14-2009 01:25 PM
Engine Mount Through bolts jamnut Engine 1 06-17-2003 04:21 PM
