1955 Wagon Transmission Problem (Linkage) - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-05-2007, 02:14 PM
I am working on a 1955 Station Wagon, installing a 350 engine/turbo transmission. The linkage from the steering column to transmission doesn't fit. Its the original linkage from a '55 to Powerglide. Has anyone had this problem before, or know where I can look for help? Any help would be greatly appreciated.
-Thanks-
Old 08-05-2007, 02:20 PM
1955 Station Wagon continued....
I am working on a 1955 Station Wagon, and I just installed a 350 turbo transmission. There is a rod, about 5/8" in diameter, sticking out of the frame, towards the transmission (on the drivers side). I was wondering if that hooks up with the original linkage, or is it for something else? And is there a website I can go to that is for Station Wagons?
-Thanks-
Old 08-05-2007, 05:02 PM
I converted a '64 El Camino from Powerglide/column shift to TH2004R without any particular problem. I used a kit from BowTie Overdrives. It is just a stainless steel rod with ball & socket joints at each end.
Pretty simple
JA
http://www.bowtieoverdrives.com
Old 08-05-2007, 06:40 PM
Last journal entry: 29 Ford Tudor
The rod welded to the frame was used with a bell crank for the original shift linkage. On both of my cars we removed the pivot rod and used a single piece of 3/8" rod from the hardware store bent to fit between the column and transmission and have never had any problems. I did use an original adjuster on the top end tho. I used a piece of welding rod to make a pattern for the larger rod.
Charles
Old 08-06-2007, 03:53 AM
aka Duke of URL
weirdest transmission problem i 've ever encountered. platynumx Transmission - Rearend 11 06-11-2007 10:45 AM
chevy transmission wiring problem davidvg Transmission - Rearend 1 12-17-2006 10:54 AM
TH-350 - Internal or Linkage Problem?? 70bird Transmission - Rearend 5 09-19-2006 11:13 PM
Quadrajet linkage problem! bildo95 Engine 2 03-22-2003 09:27 PM
Transmission problem Malibu406 Transmission - Rearend 1 09-01-2002 06:24 PM
