1956 Buick Coil Springs - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-21-2005, 12:23 PM
Maverick's Avatar
I have a 1956 Century that I pulled off a farm couple weekends ago. In getting off the ground and some tires that hold air I have discovered that I am missing a Rear coil spring. Kanters I think has them put they are little pricey. What donor car from the bone yard could I use that would have comparable springs? A big Cadillac or something? Also were could I find the Spec. on these and other springs.
Thanks!
Old 02-21-2005, 02:19 PM
ckucia's Avatar
Wish I could help
Man, I love '56 Buicks. I wish I could help you, but I don't know enough about those. Post some pics of your progress sometime though...
Old 02-21-2005, 05:43 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Try www.espo.com They sell all types of coil springs Also you can check with Coil Spring Specialist
632 W. Bertrand
St. Mary's Kansas
1-785-437-2025 You probably need to replace both springs as a new one on one side and a old one on the other is a bad idea. The old spring has probably fatigued some and your ride height would not be even and the handleing would not be good.
Old 04-07-2005, 01:42 PM
BuickLeSabre1960's Avatar
Last journal entry: Flamethrower trial
if it's anything like my '60 LeSabre than just about any gm fullsizer will work. My rear ones came out of a '88 Olds 98
leaf springs and coil overs jhenry Suspension - Brakes - Steering 2 11-25-2004 05:45 AM
Rear Coil Springs bigjoedo Suspension - Brakes - Steering 3 02-23-2004 02:02 AM
heating coil springs kid Suspension - Brakes - Steering 5 11-10-2003 08:17 PM
weight transfer with front coil springs tony350ss Suspension - Brakes - Steering 1 09-07-2003 12:20 AM
Cut Coil Springs ? zachscc Suspension - Brakes - Steering 18 01-10-2003 07:10 PM
