1956 ford fairlane trans problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-19-2007, 12:26 PM
I have a 1956 ford fairlane that i am having trouble with ever sense i changed trans fluid it will not move in drive till it gets warm will go in reverse fine what could have wrong i used type f trans fluid?
Old 08-19-2007, 12:29 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Is this an OLD trans, high mileage, recent rebuild & it sat for years??
fluid is probably not the cause.
hard inner rubber seals.
Sealing rings worn out.
IF the trans operated before basically OK.... the fresh fluid has washed out some 'stuff' that was helping the trans operate
List all of your cars HERE! Carbed95GT Hotrodders' Lounge 289 11-09-2011 06:43 PM
429 and C6 into a 55 Ford Fairlane Rons1stRod Hotrodding Basics 0 03-31-2007 11:59 AM
55 Ford Fairlane Project Rons1stRod Hotrodding Basics 9 12-26-2006 07:04 AM
1957 Ford Fairlane 500 CHRIS57FAIRLANE Introduce Yourself 2 07-25-2005 09:18 PM
Ford Engine To Trans Help davesr Engine 1 01-05-2002 08:27 AM
