1956 Thundrbird Gas flow Problem - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Introduce Yourself
Old 09-18-2004, 12:34 PM
The 'Bird has new battery , turns over well so starter okay. Clear filter but no apparent flow to carb. No spray in twin barrel. Ideas? Anyone know where I can find online manual for this car?
Old 10-17-2004, 11:20 AM
Tazz
Sounds to me like a bad fuel pump. Will it even idle or just start up then die? Will it run off a prime through the carb?
Tazz
Rat Rods Rule!
Old 10-17-2004, 04:38 PM
aka Duke of URL
Arrow
A reasonably priced reprint of the origional shop manual is available from vendors such as -this one-
