1957-64 Olds/Pontiac Differential ring gear questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-25-2010, 09:32 PM
1930u's Avatar
Last journal entry: 1930u Its just been sitting
Currently I have a 4:56 Ring and Pinion and I want to change to a 3:42 or 3:64 Ring and Pinion. Does anyone know if I will have to use a Ring gear spacer or change the case?
Thanks.
Old 04-25-2010, 11:39 PM
junior stocker's Avatar
I want to say NO, but I'm not 100% sure. Go to FabCraftMetalWorks.com; they have gears and parts for the 57-64 Olds/Pont rears, and you may get a definite answer there also. IF you're interested in selling the 4.56 gears, you may want to post them over on GasserMadness.Com. Butch/junior stocker
How bad can a torque convertor ring gear be (SEE PICS) STATUTORY GRAPE Transmission - Rearend 2 04-04-2008 08:19 PM
Is it possable to change a ring gear on a nissan sentra 1985 fumplet Engine 4 06-22-2006 04:02 PM
Broken ring gear chevelle_502 Transmission - Rearend 1 04-23-2005 10:32 AM
piston ring questions?? fireforsin Engine 12 08-24-2004 09:58 PM
Rear ends...ring gear..? 67_Deuce Transmission - Rearend 1 01-23-2003 07:58 PM
