-   -   1957 Chevy rearend (http://www.hotrodders.com/forum/1957-chevy-rearend-223480.html)
rusty duck 08-28-2012 10:55 PM
1957 Chevy rearend
what is the best way to determine what the gears are in a '57 chevy rearend? Do you take off the cover and count the teeth on the gears? what were the gear ratios on the '57 chevy rearend? Thanks
64 elky 08-29-2012 12:46 AM
Yeah you can do that but normally it's kinda hard to see the piņon gear cause it's blocked by the carrier. You should be able to find a stamp tooth count somewhere on the outside of the ring gear and normally the stamp on the piņon gear is on the flat part rear facing in the vehicle toward the ring gear and divid the two to get the ratio. Such as I originally wanted to know what my car had so I took the big number(ring gear) and divided it by the piņon gear and I had 3.23 gears. But I had a two speed power glide in my car and that ratio was common in alot of el camino's in 64.
vinniekq2 08-29-2012 12:55 AM
what cover?
vinniekq2 08-29-2012 12:57 AM
usually the ring gear has a stamp on it somewhere,like,,,, 41/10= 4.1 gear ratio. 57s were 3rd member rear ends, so if its posi then turn the tire 1 revolution and count the drive shaft revs
AutoGear 08-29-2012 06:37 AM
Aren't '57 Chev rears 'front-loaded'?
SSedan64 08-29-2012 06:46 AM
Both 57 Car & Truck were Drop out 3rd members but, 57 Truck "55T" Rear also had a 12-Bolt rear cover.
Differentials: GM 55T - Drops out the front of the housing in attition to having a 12 bolt rear cover. Uses c clip axles. Ring Gear Bolts: (12) 3 8 x 24 RH
anglia427 09-01-2012 08:48 PM
57 rear
alot of them got swapped out for olds/pontiac rears they were stronger make shure what you have first
rusty duck 09-01-2012 11:33 PM
'57 chevy rearend
didn't know that. thanks for the tip.
Cape Cod Bob 09-02-2012 03:05 PM
Turning the drivers side hub one turn while watching the pinion yoke to see how many turns that makes will give you a pretty good idea of the ratio. For instance ,one turn on the hub may give about 2 3/4ths turns on the pinion = 2.73 gears etc.
The rearend gear ratio refers to the relationship between the ring gear and the pinion gear. By simply dividing the ring gear tooth count by the pinion gear tooth count, the ratio is determined. For example, if we divide a ring gear with 41 teeth by a pinion gear with 10 teeth we find that the gear ratio is 4.10:1 (41/10 = 4.10).
Read more: Gear Ratio Calculating - Tech Article - Chevy High Performance Magazine
timothale 09-02-2012 05:15 PM
both wheels
both wheels have to make one turn, on a non posi rear if only one wheel wants to turn, then One Wheel has to turn over TWO times and count the pinion-drive shaft turns and do the math.
rusty duck 09-02-2012 10:24 PM
'57 chevy rearend
Thanks fellas. I'll do what you suggest and see what I have asap. I'll post what I find out.
