1957 chevy truck - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-02-2002, 09:43 AM
Post 1957 chevy truck
I'm building a 57 chevy truck has any one ever had
thier truck on a scale to know what the weigh it
thanks robert
Old 11-03-2002, 08:06 AM
bullheimer's Avatar
NEVER use credit cards!
Post
before i put in on a 4x4 chassis, which i would expect to weigh way more! w/ a transfer case and front axle,. with my utility box on it my 3/4 ton 55 chevy truck weighed 5050 lbs w/sbc, and full floating rear.
Old 11-03-2002, 09:22 AM
slider in wa's Avatar
Slider in Wa.
Post
Look on the door tag for your rated sale weight. My 57 3200 says she is 5000 lbs. It`s a blue factory tag.
Old 11-04-2002, 07:10 AM
Post
thanks guys that what I needed Robert
Old 11-04-2002, 07:48 AM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Post
My half ton weighed 3500 on feed store scales, but it is on a 67,78 chevy combination running gear. I am also not sure on the accuracy of the scales.
chris
Old 11-04-2002, 09:13 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
The way I weigh my cars is to throw a few newspapres in the trunk and take them down to the recycling center. They give you a B4 and after weignt ticket and pay you some money to boot! Also, that is such a tre-hugging enteprise that the sacles are probably accurate to 0.0000000001# due to all the scrutiny from our great Socialist governments!
Old 01-22-2010, 08:38 AM
the build tag in the front door jam says 5000lbs on mine also.
Old 01-22-2010, 03:20 PM
OLNOLAN's Avatar
Truck Weight
Hey Vette, Check this weight info on a '58 short/step(3104);
http://chevy.oldcarmanualproject.com...sto/58t004.htm
