1957 Chevy truck must II IFS ride height question - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
Closed Thread
  #16 (permalink)
Old 09-12-2012, 10:53 PM
Originally Posted by chevyrestore View Post
Hey I just finished my power steering conversion and ran into a few problems your going to run into, figured id let you know so it doesnt happen to you. Your going to need to get a pressure valve shim kit from danchuk or borgeson steering. Its basically a pack of shims you put behind the pressure valve on the power steering pump since the GM pump has WAY more pressure than the ford style rack and pinion...
I used 4 shims and that worked best for me. Kit is about 18 bux and no matter what your going to need it. Dont run the motor without putting the shims on first, I did and the pressure blew the seal on the rack and pinion and I had to fork out more money for another rack. That and the lines leak like crazy at the rack so make sure to put teflon tape on the threads on the adapters for the rack.
Also, when welding up the steering shaft, make sure the shaft isint too far into the joint or it will bind on you and make sure to "time" the joints by welding them in the correct position (directions show how)
hows your IFS going so far?
Hey! Sorry I'm just getting around to reply right now I've been busy doing other things which pulled me away from the build. I'm ready to get back at it and get this truck rolling!!
Thanks for the good info on your install, I hope it will save me some headaches in the future. Got any photos up of the install?? I'll try and throw somenupnof where I'm at so far....
Talk to you soon!
David
Quick reply to this message
  #17 (permalink)
Old 09-12-2012, 10:58 PM
Originally Posted by GUITAR1989 View Post
Hey man Saw you were messing with the suspension in ur truck an figured you might be interested in this thread...
Make it handle - The 1947 - Present Chevrolet & GMC Truck Message Board Network
Its full of killer info about suspension set ups and alot of the info is from a guy with a bad AutoX 1956 F100
Thanks for the link guitar! I'll have to read through when I get some free time!!
Closed Thread
Need a IFS for a 1957 Chevy Truck, on a budget pripat Suspension - Brakes - Steering 4 03-13-2012 12:31 PM
Model A ride height drop question texas97z Hotrodding Basics 2 11-22-2009 06:58 PM
Hello Everyone!~ 1957 CHEVY TRUCK HERE!! Livinthedream57 Introduce Yourself 7 05-06-2009 04:46 PM
Setting ride height for 50 Chevy truck mr52pickup Suspension - Brakes - Steering 0 04-30-2009 08:26 PM
56 Chevy Qa1 Suspension Ride Height Question bob barker Suspension - Brakes - Steering 1 02-08-2006 05:06 PM
