Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1957 Chevy Truck Panel Alignment
Old 08-23-2012, 12:42 AM
tech69 tech69 is offline
put up or shut up
you can either reposition the hood or shift the nose over a tad. Looks like both will help as it appears to be a pretty small gap on the other side in the front. From the looks of it I don't imagine much movement up top on your fender and it also looks like addressing it at the hood would help on the other side as well.
To shift the hood loosen the right hinge to the hood and bring the hood back a tad or move your hinge towards the driver's side and tighten. If the hood sits flush to the fender up front on that side than go to the driver's side hinge and push the hood forward or towards yourself and tighten. Can also semi loosen all the hinge bolts and shift it around with your hands while closed, then carefully lift the hood up enough to get a tool in there to tighten it up.
Before doing that I would check to see if the nose is square by doing some cross measuring from a bolt in the back of the fender to one in the front on the other fender. If it's not square it will most likely need to shift towards the driver's side. You can do that by loosening the bolts on your supports and holding it in place while tightening. But only do this if it's not square.
