you can either reposition the hood or shift the nose over a tad. Looks like both will help as it appears to be a pretty small gap on the other side in the front. From the looks of it I don't imagine much movement up top on your fender and it also looks like addressing it at the hood would help on the other side as well.
To shift the hood loosen the right hinge to the hood and bring the hood back a tad or move your hinge towards the driver's side and tighten. If the hood sits flush to the fender up front on that side than go to the driver's side hinge and push the hood forward or towards yourself and tighten. Can also semi loosen all the hinge bolts and shift it around with your hands while closed, then carefully lift the hood up enough to get a tool in there to tighten it up. Before doing that I would check to see if the nose is square by doing some cross measuring from a bolt in the back of the fender to one in the front on the other fender. If it's not square it will most likely need to shift towards the driver's side. You can do that by loosening the bolts on your supports and holding it in place while tightening. But only do this if it's not square. |
Thanks Tech.
I have also noticed that OEM hood hinges are very weak and the firewall they are attached to seems very flimsly and thought this might be part of the problem? I was thinking going with a nice set of billit hinges but I feel these might be only as good as what they are attached to (firewall). Or go with the hinges to make your hood tilt forward when opening, thus starting over with hood placement? I'll print your instructions when I get home this afternoon and keep you posted. I have also noticed in the past that when I close the hood after opening, the alway's tends to lift up toward the windshield and I have to force it back into place. |
| 1957 chevy truck | SoCal1 | Hotrodding Basics | 3 | 01-26-2011 02:50 PM |
| 1957 chevy truck | rpvette | Hotrodders' Lounge | 7 | 01-22-2010 03:20 PM |
| Hello Everyone!~ 1957 CHEVY TRUCK HERE!! | Livinthedream57 | Introduce Yourself | 7 | 05-06-2009 04:46 PM |
| 1957 Chevy Panel | 57 WESTY | Introduce Yourself | 3 | 11-15-2006 10:07 AM |
| 1957 Chevy Truck | alf51chevy | Body - Exterior | 1 | 05-04-2005 10:00 PM |
