1957 ford pu rear end - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-06-2006, 11:49 PM
Hello i have a 57 short box,223 - 6 W/ 3 on the tree, it is realy low geared , top speed 45 - 50 how do i find out what gears i have? thanks Dave
Old 12-07-2006, 02:29 AM
aka Duke of URL
Is there any type of I.D.Tag hanging from the back cover or stamping on the housing/axles tubes?
Old 12-07-2006, 02:37 AM
Brian_B's Avatar
Lost in the 50s!
Last journal entry: time to start body work
If the rear end is original (its possible), it was the first year ford used the 9" under the trucks. Check the VIN plate and see if it has the gear ratio on it.
My 56 is the stock rear with 3.73s. That is confirmed with the tag and checking the ratio by the turning and count method. Mine (272 Y-block V8 and 3 on the tree) runs 60 with no strain at all. I assume it will run quite a bit faster, but who pushes a 50 year old truck?
Read this thread, it explains it pretty well.
gear ratio
If you have the tag on the rear axle still try these:
http://www.kevinstang.com/Ninecase.htm
http://jniolon.clubfte.com/differentialid.html
http://www.ridgenet.net/~biesiade/Fordrears.html
Ford Granada rear end tag identification CrashFarmer2 Transmission - Rearend 22 12-31-2006 05:23 PM
Explorer Disc Bbrakes on a 9" Ford Rear End Mustangsaly Suspension - Brakes - Steering 2 10-31-2005 04:18 PM
Ford rear end genewa1 Transmission - Rearend 2 10-06-2003 08:45 PM
1955 Ford Wagon Rear End . . . TorqueU Transmission - Rearend 2 10-04-2003 11:33 PM
ford 9 inch rear end Nos General Rodding Tech 2 05-18-2003 07:37 PM
