1957 GMC rearend I.D. help - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-23-2010, 07:32 PM
It's a 10 bolt back cover,non pig rear end.Six wheel stud,sealed pressed on axle bearing.No C clips on axle.Seal seems to be 3 inches into rear housing not between axle bearing and retainer.Numbers are A45 then C30147 other ear Us Patent 1968618 also US patent 2018188.Could this be original rear end?Any help would be wonderful.Thanks
Old 04-24-2010, 09:43 AM
prostreet6t9's Avatar
Differential/Driveline
Can you pull the rear cover and get the numbers off the ring gear?
Old 04-24-2010, 07:18 PM
1957 GMC rear end
YES, 11-28-56 Dana 30403 then G1B88, Thank You
Old 04-24-2010, 08:14 PM
I'm out of town this weekend but I will look it up for you when I get in town.
You might google for a pic of a Dana 44 rear cover and see if it looks the same as yours.
Old 04-26-2010, 10:11 AM
I was really thinking that it was gonna be a Dana 44 but the 44 didn't start being put in that truck till 1960.
1954 to 1959 is should be a Dana 45. I cant get that ring gear number to come up anywhere but being a Dana 45 it's not surprising. The Dana 45 stuff is getting hard to come by.
Old 04-26-2010, 05:58 PM
THANKS PROSTEET6T9 you helped get me thinking.I was just surprised to see this rear end in a 57 GMC,I was expecting a pig.I needed to change axle bearings.Yes to no surprise the bearing on the 2 axles were different looking and different numbers.the young man at the NAPA machine shop figured it out the dana 45 had 57 Pontiac or Oldsmobile bearings so I guess I'm all set. THANKS for your help.
1957 gmc body parts klarry Body - Exterior 1 01-26-2009 11:30 AM
1957 454 GMC Pickup Project baydr Engine 3 05-26-2006 03:12 PM
1957 454 GMC Pickup Project baydr Transmission - Rearend 0 05-26-2006 03:06 PM
1957 Pontiac Rearend Griff Transmission - Rearend 3 01-29-2006 06:54 PM
HELP rearend 1970 GMC K10 digtaz Transmission - Rearend 5 03-24-2003 05:52 PM
