1957 Olds Drum to Disc conversion
Bob, I think the fastest/easiest way is with scarebird brackets. http://www.scarebird.com/
They show bracketes for your car ($115). Typically it comes with a specific list of parts you buy independently to finish the swap. They provide the year/make/model of hub/rotor then the calipers, flex hoses etc. Not only do you get to shop for the best deal, you know exactly what you have on there when it comes time to do a brake job. They take pains to design the bracket for common, inexpensive parts. Couple of unsolicited comments. High probability you will need power booster, good time to go to a split system if you still have the original single jar MC. If you are not in a rush, I'm working on a tech article of sorts, that outlines a full blown upgrade for your car that includes ball joint suspension, positive caster, antidive etc. All done with the engine in and the fenders on. |
60 to zero braking systems has your kit ,same as a 57 chevy
i got mine off e-bay ,go under 57 chevy and punch in brakes don't buy from fattrodders ,they got good deals ,but bad feedback i had to go thru the hassle of getting a refund cause they never shipped my parts ,60 -0 braking ended up beating fatrobbers ,that is the feedback i left them. |
oldguy829 - Thanks for the info, it is greatly appreciated. And no I am not in a big rush so reading your future tech article would be worth the wait. I have two projects ahead of the Olds. First I have to refinish my Mullins trailer, and second I have to upgrade the brakes and steering components of my 34 Plymouth. Will be trying to get these out of the way first, and then start on the 57.
burnt olds - thanks for the info I will follow thru with your suggestions as well. Thanks, Bob |
re: 1957 Olds Drum to Disc conversion
Mopar34 - my first draft is posted in the crankshaft coalition. Look under
37 - 57 Buick Olds Pont suspension upgrades. let mer know if my ramblings don't make sense. |
| drum to disc conversion kits | dmented | Suspension - Brakes - Steering | 4 | 06-06-2007 09:06 PM |
| 69 Camaro Drum To Disc Conversion | kellycat | Suspension - Brakes - Steering | 3 | 01-16-2006 01:18 AM |
| drum to disc conversion. | 409guy | Suspension - Brakes - Steering | 8 | 09-05-2005 08:03 PM |
| Hotrodders Knowledge Cluster: Disc Brake Conversions | Jon | Suspension - Brakes - Steering | 0 | 08-29-2003 03:34 PM |
| 55 chevy bel air drum to disc conversion | tk6002 | Suspension - Brakes - Steering | 1 | 11-25-2002 09:56 PM |
