Demon carburetor Free speech parts auctions.
Bid on used parts to help fight the frivolous lawsuit filed against us.
Click here for details.
Parts currently up for auction: Don Garlits engine emblem, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 01-29-2006, 06:39 PM
Griff Griff is offline
1957 Pontiac Rearend
I have a 1957 Pontiac Super Chief and I am trying to find out if anyone knows of a rearend that I can swap with the original. I haven't done anything under the car yet so I can give you any information on the stock rearend. If I have to weld on new brackets, get rid of the leaf for coil-over, it doesn't matter. I just need to make a change. I am putting in a big horse small block with a 400 turbo and I need a rear end for the car. I know that I can go with a custom 9 inch but there has to be something out there that will work.
Help please!
Old 01-29-2006, 06:44 PM
BOBCRMAN@aol.com BOBCRMAN@aol.com is offline
re: 1957 Pontiac Rearend
Olds and Pontiac rears were what the old drag cars used, back when. Very strong. Rivaling 9"Fords. Only problem now is internals are getting scarce..Bearings and seals are common but serious gear ratios and posi units are like hens teeth..
Old 01-29-2006, 06:51 PM
I will check the measurements on that rearend sometime this week and talk to the local rear end guy about a swap. Thanks
Old 01-29-2006, 06:54 PM
xntrik's Avatar
xntrik xntrik is offline
Save a horse, Ride a Cowboy.
Depends on your goal.
I would stay with new custom leaf springs and go to a Ford rear end.
If you want to do a 4 link or even a 4 bar with air suspension, go for it.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "1957 Pontiac Rearend"
I need some input on putting a Ford rearend under a 1972 Dodge Dart onebadmerc Transmission - Rearend 7 12-21-2005 10:30 PM
Hotrodders Knowledge Base: Transmission - Rearend Jon Transmission - Rearend 0 11-26-2005 06:23 PM
pontiac rearend disassembly xtremcablespeed Transmission - Rearend 5 12-10-2003 07:48 PM
Advice on Pontiac rearend/ trans swap Vaughn68 Transmission - Rearend 3 11-25-2003 07:38 AM
Info on 68' pontiac firebird 10-bolt rearend Adrenaline_Fiend Transmission - Rearend 6 10-17-2003 09:30 PM
