1957 three speed overdrive transmission.. - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 07-28-2006, 12:02 AM
farna's Avatar
Last wiki edit: AMC V-8s Last photo:
Wiki Edits: 14
The OD will automatically come in (provided the handle is pushed in) when the vehicle reaches 28-32 mph (depending on make/model -- different governor settings). Just let off the gas to take pressure off the trans and it slips right in. Keep on the gas and it won't shift until you press in the clutch. Won't hurt if it shifts into OD in second gear, but most cars aren't geared to run over 30 in second normally. All OD equipped cars will have a very low rear axle gear -- 3.73-4.10 for the old cars. OD mainly gives a lower first gear, though the axle ratio will work out to be a little higher than a non-OD equipped car. The BW OD units are all 0.70:1 ratio.
NEVER try to pull the handle out while the car is in OD!! That can cause internal problems!! To lock out of OD you either slow below the cut in point where it will automatically drop out, or accelerate until the kick-down is engaged then pull the handle before letting of the gas. I've run one of these for a while in a couple cars, though I run an auto OD in my car now. They have to be wired correctly! I ran one with an EFI engine. I didn't think the computer would like the coil being grounded, so I ran a relay to the ignition module and had the kick-down cut power to the relay momentarily instead of grounding the coil. Worked like a charm!
  #17 (permalink)
Old 08-01-2006, 03:54 PM
sparkplug1's Avatar
tranny
Well my buddy got the tranny home and the overdrive selinoid was smashed in shipping...As well as other things.. He is not 100% sure what all it is missing..Bummer Well now we have more to fix.. Does anyone know Who i may be able to send this to, to get rebuilt??? Any help would be appriciated...Thankyou Randy P.S. I will be going to Jefferys tomorrow I think I should have some new pictures to post.. Thankyou for your help Randy
  #18 (permalink)
Old 08-01-2006, 04:25 PM
35WINDOW's Avatar
Last journal entry: Engine!
My Dad bought a new '55 Chevy with a 4.11 rear end and the 3 speed OD-I loved that car! It had a 265 (which was replaced in '63 with a 327 (but he kept the Tranny) and it hauled our Camper Trailer all over Colorado, up nasty Passes and did it well while getting gas mileage in the low 20's. That Transmission was a wonder for it's time-
  #19 (permalink)
Old 08-01-2006, 05:54 PM
sparkplug1's Avatar
Well I found a 57 cable for the dash and I just purchaced a replacment Governor that got smashed....It was the Governor no the selenoid..Thankyou Alen Colvin for the Chevrolet by the numbers books.. It has a whole schematic on the tranny and overdrive unit....Thats Awesome!! I think the Goverenor was the only thing that got damaged...We will see though... Hopefully We have all the right stuff now..I will get back to you guys on progress...Thankyou Randy PS still looking to get this rebuilt.. Anyone knows anybody that would help.. Thanks
  #20 (permalink)
Old 08-02-2006, 02:30 AM
farna's Avatar
Wiki Edits: 14
Search the net for manual transmission rebuilders. There's a place in Greenville, SC, that rebuilds manual transmissions. They rebuilt my BW OD trans several years ago. I just can't recall the name and don't have accessto my records.
  #21 (permalink)
Old 08-16-2006, 04:36 AM
sparkplug1's Avatar
Well I bought a new governernor and an overdrive cable also.. The tranny I got was in suprizingly great shape..Now I am sending it to a local rebuilder to see what he can do with it.. Once we broke down the parts it was pretty simple.. Thankyou for all your guys help and I will try to post the project as it goes on.. Thankyou Randy
  #22 (permalink)
Old 01-19-2012, 05:41 PM
BW 3 speed with OD
Hi, I have a '55 BW 3 speed trans with od and i need some help finding where / how i can fabricate a shift linkage for a floor shifter. None of the shops in my city know how to do it. It needs to look like this:
/Users/JimShelton/Desktop/1957 overdrive tranny.jpg
The one i have does not have that linkage. Where can i find it? Thanks!
Recomendations On Buying A New 4 Speed Transmission DarwinBrooks Transmission - Rearend 3 02-09-2006 08:15 AM
I'm going to make a bonfire out of my car blown69stang Engine 36 08-22-2005 03:36 PM
4L60E trouble with overdrive Please Help Transmission - Rearend 2 03-19-2004 07:20 AM
Overdrive Transmission sb72elcamino350 Transmission - Rearend 2 11-22-2003 11:43 PM
351C - overdrive transmission Steve_M Transmission - Rearend 7 09-16-2003 05:50 AM
