1958-283 chevy p/u - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-03-2003, 05:08 PM
Red face 1958-283 chevy p/u
whats the best way to go for the most HP in a 283
Old 04-04-2003, 04:44 AM
Wink
If you want to keep your 283 original. Try puting in a 3/4 cam one in the 318to418 lift that will up your power. or open your wallet and build a jet engin.! <img src="graemlins/pimp.gif" border="0" alt="[pimp]" />
Old 04-04-2003, 05:13 AM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Post
A set of larger valve heads, such as a set off of a late model 305 would help with flow and keep compression up. Add a dual plane after market intake and 500-600 cfm Holley carb, and a cam in the 215 duration range. Last, A set of 1.5 inch tube hedders will help on the exhaust side.
Chris
« Parts? | 59 283 »
