Demon carburetor Get parts for cheap, all for a good cause.
Parts auctions to protect free speech online.
Click here for details.
Parts currently up for auction: Rat rod chassis parts, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 01-01-2007, 09:16 PM
bigwoodbass's Avatar
bigwoodbass bigwoodbass is offline
1958 Cadillac Coupe Deville
I have a 1958 Cadillac Coupe Deville, in about a million pieces. The guy I bought it from sold it to me because his teenaged son started “working” on it and took it all apart and just left it there to rust. I had to make three trips to get all the pieces, but it is at my house. I had dreams of trying to get it as original as possible, but the more I look at it the more I am realizing I should make a nice custom out of it. I want to start with the engine, the front fenders, hood, grille and bumper are off, so I figure that this will be a good place to get going. The original engine is not running and is in pretty bad shape. I think it would be best to pull the stock V8 out, save it and find a 1970’s Cadillac 472 or 500. My questions are: is this a good idea, can I use the old tranny or should I change that too, what would be the best engine (and tranny) to use?
Old 01-02-2007, 05:09 AM
1957plymouthhemi 1957plymouthhemi is offline
re: 1958 Cadillac Coupe Deville
I did a resotration on a customers 57 Caddy (basically the same car you have with single headlights), building the stock 365 and Hydro is an expensive proposition.
Personally as I like same brand engine swaps and the 58 is a heavy car, I would definatly go with your plan for a 472/500. With the amount of torque you have I would leave the engine basically stock, maybe add an alluminum intake to save a few pounds on the engine. All of the accessories (AC/PS/alt) will easily fit under the Caddy hood.
For the tranny I would use a BOP TH 400. Besides being a more modern transmission with readily available parts the electric kick down makes life a lot easier than routing a cable/rod type linkage. The Caddy will have an X frame, so you may have to dig up a short tailshaft 400 instead of the long tail shaft units that are normally found behind 472/500s.
The drum brakes on the car a large and work well (although the booster is a bit pricey to have rebuilt), othewise someplace like Willwood might be a good place to check for a Disc brake conversion.
Old 01-02-2007, 11:11 AM
Thanks
Thanks so much for all the inormation you gave!
Old 03-25-2007, 07:36 PM
customkarl customkarl is offline
58 coupe deville
If your ever interested in selling the caddy let me know Thanks Karl
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "1958 Cadillac Coupe Deville"
1972 Cadillac Coupe DeVille Interior EazyDuzIt102 Interior 1 03-07-2006 11:53 AM
1958 cadillac bigwoodbass66 Introduce Yourself 2 12-28-2005 11:03 AM
1965 Cadillac Coupe DeVille Fragzem Transmission - Rearend 3 07-09-2005 09:29 AM
Help! 83 coupe deville :D Kenny13z3 General Rodding Tech 5 11-17-2004 09:07 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
